I have a 2007 Z71 4WD Silverado. Front brakes randomly lock up. Starts with a slow rub, I can feel the truck not accelerating like it should, and brake pedal stiffens a little. After a mile of driving 65 mph, 2-3 miles if I'm going 25-35 mph... Brakes completely lockup, truck won't move at all. Once it locks up completely, brake pedal is very stiff, takes a lot to depress it. Front wheels get really hot, back wheels feel normal. Brakes will break free after letting the truck sit for about 2 hours, and works fine after.
This happens sporadically, once every 2 weeks or so. Cant figure out what triggers it, happens driving down highway, back roads, wherever. Had the calipers, pads and brake fluid replaced 4 months ago. It was happening before then, so that didn't fix it.
Any thoughts on what might be causing this? Thanks in advance for any replies.
The rubber, flexible brake hose attached to the caliper may be deteriorating internally. The hose will not allow brake fluid back out of the caliper when you let off the pedal.
As the dragging caliper heats up, the pressure builds. Also, with every stop, the pressure also increases. Eventually, as you have experienced, the brake completely locks up.
The master cylinder may also be the culprit but I would personally start by replacing the hoses.
Yes I second that motion replace the rubber flex lines. Very common issue.
As was mentioned, the only other thing would be slow vacuum leak in master cylinder which gradually applies the brakes.
Check your brake booster for brake fluid. Had the same issue with mine. Fluid leaked from the master into the booster causing the brakes to start to engage by themselves. New Master Cylinder and new Booster fixed the problem for me.
  • 3 years later...
Front hoses on both side have been replaced, so have calipers and abs. As well as the hub Barron’s . Still having the brakes locking up. Don’t know what else to replace??? Help!!!!
Jesse, did you figure anything out? I have a 06 I have been battling with for almost a year now on these brakes, I have replaced everything but actual lines, I have brand new calipers, pads, rotors, master cylinder, brake booster, rubber lines on both fronts, lasted a couple months and just the other day she locked up and now doing it all over again! I’m lost
truck does it a lot again, about 10 minutes of driving you can feel the brakes start to drag, what I did to unlock brakes was cracked bleeder on driver caliper, after doing that it’s fine for another day almost!
here’s another one, on my way home from work, felt it start to drag, so I started wobbling steering wheel back and forward quickly and slightly, nothing making truck shake, but it made the dragging go away…. I’m telling y’all I am lost, I need help
Edited by Blknyellow517
  • 2 years later...
Like this shared post, I have done ALL of the above with the same results
Has anyone found a legitimate solution for the well documented front brake issue???
*2006 GMC SLT, Crew Cab, 5.3L
Did you not replace the brake lines Jimbo?  They can collapse internally.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 481 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
