Mylink
Bowtieguy69
Hello all. Hopefully I'm posting this in the correct place. I just purchased a 2015 Silverado 1500 and it has the 8" Mylink screen with Navigation etc. I was reading through the manual and looking at the GM videos on the system and I went to change the home screen display to a different customized home screen.........velocity, etc. and it's not there in the display settings. Is this a programming issue or do only certain trucks have this option? Just curious and thanks in advance for the help. I love the truck and all seems to be great with it except for this one strange setting.
yeah, I kind of miss that option. I thought that the blue/orange theme looked better than the black theme in my 16 for the gauges.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 683 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
