Gibson dual sport
Slamminv
Not sure how, but if any of you guys are interested I just picked up a stainless Gibson dual sport exhaust for my 2015 Silverado for $347 shipped. Not sure if this was a mistake on their part or if they are running some sick deal. Summit part no. is gib 65656.
Dang that is a good deal. Wouldn't have fabbed my own if I knew that deal existed!
Yes it was when I called as well but I told them to do a price beat from another site that I saw it on and they came back with $347
What site did they price match?
Auto Anything was offering 10% off using code 358910. I chatted online with a gentleman named dale from summit and advised him and he offered me the exhaust for $347. I didn't question it and just paid.
Just got done dealing with Summit. That deal isn't gonna happen again. They said the price is $626 and you need to give us a link to a better price if you want it beat. Autoanything has it also for $626 but is doing 20% off orders over $150. I told him that and he offered to beat them by a dollar. I told them they can keep it. I don't know how you got so lucky man but good for you. Wish i would have gotten to talk to Dale
I gues it was a one time lucky deal. Sorry guys was looking out for the fellow members.
