Best Custom Tune for 2015 6.2L 8-Speed
I recently got a custom tune on my 2015 6.2L 8 Speed sierra after finding out the bully dog programmer is not compatible. The only reason i was considering bully dog was because my local dealership said they would install it and cover it under warranty. My tune is a bit over the top and can make my truck very jerky to drive. I was hoping to gain the power without losing the smoothness that the truck originally comes with. I am not 100% happy with the tune, and was wondering if anyone could point me in the direction of someone that can write up a good tune for my truck.
A dealer that will install a tune and still have it covered under the warranty? I smell BS. I would really check into that if you're concerned about keeping the warranty. I've heard a lot of good things about Blackbear. I just don't have $600 to spend on a tune.
Yes, I thought it was interesting myself when they told me they could install 2 programmers on my truck without voiding warranty.1 being the bully dog. Assuming money doesn't exist, would a blackbear tune be the 100% best route to go?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
