AC doesnt work when its on 5?
Hey guys, 2006 gmc sierra 1500 sle. I have the nobs that i have to turn to select the speed i want the AC/Heat to come out, but while i was on my home from work today, all was well, it was working perfectly fine, then all of the sudden it stopped working. Its so weird to me. It works on settings 1 2 3 4 but it does not work on 5. Please let me know what you think!
-Brenden
Usually a new resistor comes with a new connector
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
