Black Bear Tune in NJ 10/20-22/2016
I just signed up for the in person tune scheduled for 10/20-22 in Somerset, NJ.
Anyone else planning to go?
How much is it?
Also in south jersey....been actually wondering if he's ever going to be local
Per the info from Black Bear: The total for both the tune and Autocal would be $579, $300 for the tune and $279 for the AutoCal.
Also, just to be clear, they are coming to Somerset, NJ, which is near New Brunswick. Not exactly South Jersey, but only about an hour up the turnpike from where I live.
I would rather drive the hour to attend a live tune event then try to this by mail :thumbs:
Any of you guys in Camden County?
I don't think I'm going to do it this go around since I haven't done any mods yet. It's a shame because I've been watching his calender waiting for it to be remotely close.
But would be quite interesting to feel the difference in someone elses truck. Specifically the transmission.
Im in Camden County. I have no mods either but this truck shifts like sh!t at low speeds. Its either I tune it or trade it in.
I'm in Camden County too. Have been on the fence about a tune, but just can't take the crappy shifting anymore. I need to do something before I'm forced to trade on a Ram or Ford.
Well if you're doing it, would be awesome to ride shotgun for a few minutes. Or just trade trucks for 5 minutes if you have any interest in driving a 6.2.
I generally forget how bad the transmission is until I drive another car. My wife has an acura with a 6 speed slush box that honda has been using for a decade, and it feels like a porsche pdk in comparison.
Maybe I'll try to make it over there to see first hand how it's going and decide from there. I'll check back to see what day you guys are going.
I'm game to having you ride shotgun if you want to check out my truck post tune.
Funny you mention the Acura. My wife has a Nissan Murano with a CVT. No shifts at all and with the 3.5L Maxima engine it puts out pretty decent power. Plus its very torquey as soon as you hit the gas.
That's absolutely part of the reason why I want a tune. Even my wife says the Sierra's driveability is total crap. If she can tell sitting in the passenger seat, I know there's a problem.
is this the same Phil Devtec from g35driver lol?
Actually it is!!! Lol!!!
Phil DeVtec on every damn car forum...lol!!!
Have I met you before (at a meet or something)?
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
