Let's see some sound systems!
DTOMKIDD
That looks terrifying!
It's fun for me.
There's alot of stuff added in my truck.
Aftermarket stereo.
AUX switch retrofit.
LED lights front and rear.
Front and rear dash cameras.
Subs and amp.
Foot well lighting.
Makes for a lot of wiring.
Sent from my Pixel XL using Tapatalk
  • Replies 50
Once me and marv88 collaborate a bit more I will post some pictures when we do ours. I want to keep th3 oem head unit. We have discussed doing a hybrid audio component set on an arc audio 4ch amp with hi/lo inputs. So no dsp needed there. No sub because I know something behind the seat won't be enough and I'll end up doing a blowtheough. Any regular cab setups ?
I went nice and simple for the mean time until I have enough courage to do a blow through. I went with a Rockford Fosgate R2 12" swallow subwoofer behind the passenger seat, and a Rockford Fosgate R750-1D amp. Kept the oem head unit and went to my local Bestbuy because of the warranty they offer.
  • 4 weeks later...
If it has bose dsp is still gna be the way to go bc of the factory equalization and possible need for signal summing. High level into an amp won't correct those. And yeah I've heard damn good bass with 2 JL flats under the seat
Sent from my SM-G930T using Tapatalk
  • 1 month later...
2 10" powerbass subs In a bassworx box under the rear seat in a double cab. Ken wood digital amp under rear seat. Love the full sound these get. No seat spacers the box fits perfectly
I built this box a couple months ago, but have since modified it to fit better under the rear seat. This is a sealed mdf/fiberglass enclosure with maybe .6-.8 cu ft. It hits hard.
I am in the in the process of building a ported enclosure with, hopefully, at least the recommended .95 cu ft for my JL12"tw3.
Probably gonna take me another week to get it in my truck and finished.
Also, I have never built a ported box so this is gonna be interesting. I tried to get the proper port length but I am not certain this will do and it is hard with the limited uneven space I have under the backseat. Wish me luck.
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
