Let's see some sound systems!
DTOMKIDD
I have the Bose system and added a Rockford Fosgate 10" 500 watt slim woofer under the rear seat. Sounds good. This isn't crazy loud bass, didn't want that. Need more bump though. I didn't get the center console with sub.
Is that the GM storage bin just chopped off? I really need to get storage under the seat. I had the DuHA but sent it back after installing the Kicker Sub.
  • Replies 50
I did 2 12" subs in my Sierra. No spacer for the seat. Perfect fit. Put the amp behind the rear seat.
Sub box was made by SoundOffAudio.
2 12" JL Audio 12W0v3.
Self install was pretty easy did it with a buddy. Buddy of mine said the power wire would be the hardest but knocked it out in 5 mins running it through the grommet.
fdaa20f9cc81ffde184d05f135d293e6.jpgef4df820ef2d0819da87fdb777bb7d58.jpg7428b93497e752c808ebc6bd1844c13f.jpg8a62e2927b87e3d7c959d0b44b07ddff.jpg
I bet those (2) 12s" hit a hard!
You can meet me some day in Dallas and hear it for yourself, but yes they do. My buddy that helped me install this system used to have 2 15s (no use of a backseat at that point). And he was impressed. He is now rocking 1 15" and is now thinking of swapping to my setup.
Yes it is. Had the shop cut it to fit the box and sub.
I put two audio mobile 10's in a custom fiberglass enclosure poured into the GM underwear storage tray. The box is split into to in case I need the room I can take one out and still have some bumps...lol. The amp is mounted behind the rear seat and the LC2 controller is mounted under the center console.
5B5A70B2-706F-447E-8EA3-52CB20C2C5EF_zps
526D0DEE-8C95-4A35-8FC0-B351320CF70D_zps
EB6497CE-FFEB-4AB3-ACA8-225D0EF71265_zps
I like that. Simple, clean and super easy to take out for extra space.
Sent from my SAMSUNG-SM-G890A using Tapatalk
That's what I was going for...headrest monitors go in tomorrow
Very nice... so I'm guessing your running an aftermarket head unit right?
  • 1 month later...
I've heard so many mixed reviews on the kicker vss system I wish someone local had one so I could here it for myself. It's a very expensive system and I'd like to be sure it's what I'm looking for
Have you thought of sound deadening? I know these trucks are quite already! I did almost my entire interior roof, floor, back wall, doors, pillars... I can here a misquote fart now! lol
It really improved my Bose sound system, and if you added a better system it would be even better.
Here are some photos. Everything just bolts on to existing bolts. Harnesses are plug and play behind the radio. Amp goes under the driver side dash (next to brake pedal, above the X61A Fuse Block. All wires ran under the carpet. (2) Power cables are routed through the firewall and connect to one of the battery terminals.
It sounds great! Not a "wake your neighbor" kind of loud, but is a welcomed upgraded.
Im curious did the speakers add more on top of the kicker vss power stage system?
The speakers did add more to the overall sound. The mids and highs are nice now where the stock speakers seemed to drown out as I turn it up.
