Plashlights LED replacement?
In all seriousness stay away from anything that says COB LED. Just look at thier company page:
http://www.cob-led.com/about-us-COB-LED-Chips-on-board-China-manufacturer-profile.html
Lightspot specializes in LED since 2004 year. . For the past years, Lightspot commits itslef to make more reliable and more brighter LEDs. With our own technology, high light efficacy and low thermal resistance and high reliability can be achieved.
One should only run genuine Philips LumiLED chips everything else is a knock off.
I do see that they have a bracket kit that can be used to put LED fog light pods in the factory fog light location. That could be interesting.
LINK
Thanks for the info! I might just save up and install 16 headlights instead. Although I will be buying one of these from them!
https://plashlights.com/index.php?route=product/product&path=141_80&product_id=131
I like that! And I am not even from Texas (or the US). Would be a badass roof mounted bar. OSRAM® OSLON LX ECE LED's are much better quality, still not Philips but they are a name brand and established company.
Just remember lightbars are mostly useless or I mean non functional. I would categorize these as more for looks which is fine unless you actively offroad and at night which would be rare or like work in the oilfield or own a ranch. They are not road legal. I was honestly looking at a lightbar before doing my headlamps and it was suggested I may want to upgrade what I have before adding more. It was bang on advice and I am 110% glad I followed it. The headlamps are infinitely more functional than a light bar for 99% of people out there.
