battery not charging and battery light
Hello All,
2003 GMC Sierra 2500HD 6.0 AT 4x4
after experiencing the random REP mode and doing some scanner diaognosis we decided that the alternator and battery should be replaced.
after replacing them everything seemed fine for the first 30 mins. then the battery light and "battery not charging" would flash on for a second or 2 then go away. It does this randomly.
any ideas?
thank you in advance,
Tony F.
is the belt clean and tight? connectors/wiring between the battery, frame and alternator are good?
everything seemed fine when I replaced them. going to re do connections this morning.
Where did the alternator and battery come from? Is it Chinese junk or OEM?
alternator came from NAPA, battery from Wal-Mart
If the battery and alternator check out fine then you need to check all the main wires for corrosion, tight connections and any possible rubbing issues where a wire may be shorting or getting hot or drawing an above normal load.
DEWFPO
