Fuel economy down 5-7mpg after dealer replaced cats/downpipe with P042
Haus_Z71
I can't get a break with this truck.
After having a recommended Direct Injection valve cleaning done, the truck threw check engine light with code P0420.
Dealer replaced cats to fix the code.
Since then I've noticed a huge drop in my fuel economy. Down to around 10mpg around town. 14mpg on my 400mi average. But, oddly enough, my highway driving while cruising at 60mph still results in around 20mpg.
So what the hell could cause only city driving to suck? I am driving like a grandpa.
Here's a short clip of the mpg while slowly accelerating, which may mean nothing but seems odd that it shows that low mpg while slowly accelling.
https://youtu.be/Rgbf2Y8QdWM
Just read a couple other topics and around this time the temps dropped by 20 degrees. Sounds like cooler temps, along with 2 minute remote start in the morning may be accounting for some of this decrease. I didn't notice this last winter though. Still doesn't seem quite right.
Lower outside temps means more fuel into the mixture, also winter fuel shipped out last month to all refineries, add to that remote start events and you can kill fuel mileage pretty quick.
My truck gets horrible mileage when cold and in city traffic.
If I'm just driving to and from the office in the cold, which is 10 minutes away in 25mph residential streets, I probably average 10mpg babying it.
The same truck has averaged 25mpg on flat surface at 60-65mph
  • 3 weeks later...
My mileage readings dropped after installing a catback system. Disconnecting the negative battery cable for 10 minutes brought the readouts back to previous levels. Don't take the readout for gospel. Do the math. Divide miles driven by gallons used for the REAL gas mileage. If it isn't at least 16mpg, you've got a problem.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
