Nerf bars Yes or no?
Personally id stay away from them, i took mine off after a few years because for one they mad my truck look a lot lower, which im not a fan of, and two, i find them through harsh winters to build up salt on the inside and really rust from the inside out.
I ordered a pair of Nerf bars, mostly because my wife is too short to get in and out without a step. If they rust after a few years, replace them. Not that expensive.
if you do, find a set that have seal ends. www.westin pro traxx 4 . is one copany out there . good luck
If your short like me ( 5'5¼'' on a good day ) it will help getting in and out without ripping the side of your seat eventually, but you can also get just a side step which is what I plan on getting.
Picture sample ebay.gif http://www.ebay.ca/itm/Left-Right-Bully-Black-Truck-Nerf-bar-side-Step-Silverado-2500HD-Tahoe-Suburban-/160773276805?hash=item256ed58485:g:8gMAAOSwV0RXvPHo&vxp=mtr
