Those look great. I have those same rims and I will be getting the duratracs. Does anybody know why some people's trucks rub using this size and some don't? I'd rather not spend the money and time install a level yet if I can get away with leaving it stock and not rubbing with those tires. They don't rub at full lock or anything?
Here are some more pics of mine at full lock. They do not come anywhere close to the front sway bar or any other suspension parts or frame (first 2 pics). And at the back rear side of the tire they do come close to the carpet wheel well liner but does not ever rub (3rd pic). I can slide my fingers between the gap. On the front side of the wheel well there is even more room (4th pic). I see no signs of rubbing or scuffs anywhere and with the closet spots just being the wheel well carpet material I dont see any big risk. And I've had these on for almost 37k miles.
I had this exact same tire on my 2005 Silverado and it did rub slightly on the suspension at full lock but not on my 2014.
Thank you! That really helps. Makes me feel a little bit better about making the purchase. It definitely looks alot better without those little 255's.
****update****
I went to get my LT285/70R17 duratracs put on today. And they rub the rear wheel well ALOT. Luckily I had them only mount one to check. So now I'm back to my 255's all around unfortunately.
Looks like I'll have to raise the front 2 inches before I can get them mounted.
****update****
That is surprising. I just looked online amd my Toyo's are 11.5" wide and 32.8" tall and the Goodyear's are 11.5" wide and 33" tall.
Mine is a 14 extended cab, z71. What is your 15?
  • 5 weeks later...
Finally leveled the front and got the tires on.
Didn't get the blocks on the back yet as my floor jack broke doing the front.
Alignment seemed good after the level but I got it done anyway as they suggest and now it pulls to the right.
So now I'm sitting back at the shop again hoping they can get it straightened out.
I think it looks alot better though.
Too bad I can't seem to figure out how to upload pictures. It says error file too big.
I'd do the rear blocks before the next alignment. I did the 2" front, then later did the 1" rear block and the steering wheel was off a bit surprisingly. Then I did the front 1/2" ....and had it aligned again. I know, should have done it all at once.
And I've seen many stock height trucks put 275/60 20's (33" tall) on with no rubbing issues.
Well they got it fixed today at no charge. Turns out the first guy that did my alignment didn't have the steering wheel straight lol.
And really? Hmm I didn't think the rear would mess with the alignment at all. I guess I'll find out lol.
I got 285/70r17 duratracs. Stock they rubbed the wheel well enough I had them take it back off. Good thing it was only a test fit.
But now they look great and no rubbing at all!
Now my truck looks like it should and I'm happy lol.
Any pics of this and what wheels? Exactly what I was looking to do.
And OP - I think you might have a slight bit of rubbing due to that width of tire. 285+ normally has some trimming.
I have 275/70R18 wrangler duratracks on my truck with no issues. I have a Rancho QuickLIFT level though. f28e8f0cad1fcb5e627bdebca4df4e15.jpg99f17e0874ee16aa05c376124b1c3e0f.jpg
I'm Leveled 2.5 inch on a 2015 Sierra with 285/65/18 and I rub on big bumps slightly and when backing up wheel fully locked it catches my mud flaps badd07052b37c1ee4e630cfa5a1ffa57.jpg
Sent from my SM-G930W8 using Tapatalk
My LT285/70R17's (17x9 0-offset 5" backspace wheels) never rubbed until I put a set of Weathertech no-drill mudflaps. Now I rub in reverse at full-lock.
Edited by HondaHawkGT
I guess each truck is just a little different.
It was worth all the work. It's not too tall, just gives it a bit more aggressive stance.
Could someone tell me how to post pictures on here?
    sportfish17
    sportfish17
  • Who's Online   5 Members, 2 Anonymous, 2,009 Guests (See full list)
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
