Reattach wire to harness
I had a wire come out of its slot in the harness, curious how I go about reattaching.
The harness is located on the steering column and the wire goes to the low beam lights.
In the image attached it shows the harness and loose wire below.
Moving to correct section, the How-To section is only for write ups on how to perform modifications.
Is this for your 99? Can you show an end view? If you don't want to jimmy it you will need to crimp a new pin onto the wire and insert it in the connector if it isn't damaged.
