7.4l TBI timing
Hey guys,
Quick question, well first, the scenario...
So, a few months back I bought my '95 2500 with 7.4l and 4:10 full floating 4:10 rear end. This is my daily driver and to pull my 9000 lb travel trailer. When I bought it, it had several failed sensors, distributor issues, etc... I repaired all, timed it and shortly after set off to Florida with the trailer. It ran/runs well, but is a real dog up hill. It sounded as if the timing was retarded pretty bad. During the trip I changed the timing module with no difference.
I made it down and have since played with the timing. Timing was set to 4 degrees btdc. Milage was approx 16.5 (not horrible), but I have to play with the pedal getting on the freeway to get the most out of it. If I advance the timing to say 8 or even 10 degrees, it seems to run better all around and really wakes it up from a power standpoint, but the milage drops like a rock. Not sure if one of the previous owners put a cam in or not, they did put a k&n air cleaner on.
Does make sense that with more power, the fuel economy suffers? Thoughts?
Thanks in advance!
Lorne
TBI works on velocity, that big engine is sucking that TBI unit like a straw.
it is a lot like the old carbs, a little bit smarter.
if this gets really frustrating, slap a big holley with a plate... msd has digital controls for any ignition.
Any errors at all straining that timing on that little TBI...
kaboom.
staying retard time is safe.
I just got the mpfi fuel injection in 2015. Went a long time with carbs.
Thanks for the responses. EGR checked ok back when I got it a few months back.
It just seems so strange to me the the performance is so much better, but it seems that for every degree I advance I lose 2 mpg. The improved performance made me think a bigger cam may have been installed. Timed normal it even sounds retarded as the RPMs climb. Can't argue with the fuel economy, but pulling up large hills I feel like I should get out and push and max speed is 40-45 mph.
A carb would definitely supply more fuel. There's a way to fool the computer?
