My 16 2500hd silverado has a constant noise in 4 wheel drive. it sounds like a bad bearing/gear. No noise in 2wd. it is like a whine that goes up in pitch when accelerating and when coasting down a hill it makes a lower pitch growl. truck only has 4,000 miles. Any Ideas? I would love to pinpoint it to make sure the repairs are diagnosed correctly. I will take it in to the dealer when the weather gets better.
Thanks
Scott
Do you have the manual shift tcase or electric?
I know they have a TSB on mine for 4wd noise that has no resolution. At one point it was a bushing in the shift mechanism, but they since retracted that. I had mine in twice for it, and they finally told me not to worry about it...bought the truck new in 2012, sit with 95k on the clock.
Supposedly no damage or wear from the noise, although it sounds like a bearing in the front axle or the 4wd portion of the transfercase is about to blow apart.
it's electric, it has the button on dash, it's an LT 2500hd that is pretty loaded. The noise sounds like my Muncie M22 rock crusher in my Camaro, but I thought these trucks were supposed to be pretty quiet
Scott
Mine makes the same noise, dont think you will find anything wrong. It just different gears heavier duty than the 1500. My 1500 was quiet in 4hi and when I switched over to 2500 it was noticeable. But I had it checked very thoroughly by a good dealer that actually cared. I have since moved on got used to it dont worry about it anymore. I use my 4 hi at least once a week all year round its doing fine. Spooky427 thats a sharp looking truck you got there.
Check the transfer case fluid level, mine was doing that and I found the transfer case took almost a quart of fluid till it ran out the fill hole. It reduced the noise a lot but 3/4 ton trans cases are a little loud compared to the 1/2 ton case.
Thanks for the compliment Crankman! My last truck was a F350 7.3 and you could hear it when it was in 4 high but not this noticeable. I will check the T/C fluid and know the service manager at the local dealer and will let them check it out. I have no issue with it if it ends up being the way these are made. We do get some snow now and again, so I don't need this thing to break at an inopportune time.
Thank you all for taking the time to respond and appreciate any further feedback.
Scott
Scott
Spooky427 I just bought almost the same truck two months ago and the first time I put it in 4x4 I said the same thing. Not sure if you ever got an answer to your question? It sounds and feels like granny gear in my grandpa's old 78. My 2011 2500 never sounded like this and I use to drive truck and trailer down the high in 4wheel hi at 60 no problems ever.(very snowy/slushy roads). The new truck is fantastic but the noise is a little concerning.
EbaBlacknchrome, I have not brought it to the dealer yet. You describe it perfect with the granny gear! I did check the transfer case fluid and it is a little low, but not that low. I will pick up some dextron 6 next time I go in to town. I want to put the right stuff in it. I should be talking to the dealer on a couple of weeks so I will have them drive it and let me know. It won't bother me if it is just supposed to be that loud. if it is in 4X4 i'm usually not going that fast.
Scott
Scott
I have the same noise in my 2015, took to the dealer and they stated that the 2500's and 3500's had a real whine to them in 4x4. That's all I got from the one Chevy dealer where I live, next one is 400miles away so I'm curios to see what your dealer says.
Yep my 2011 was very different in 4hi. yes my 16 has a whine. It has a very different feel in 4wd. I have 1500 miles on it so far. Like you guys said when it goes in for oil change Ill have them look at it. Sounds like its just how they are built. Not completely confidence inspiring on those snowy days.
Not sure if anyone changed out their Tcase fluid early, but I like to change out the factory fill on all my drive train before 5000 miles. When I did the Tcase the magnetic plug looked like someone had stuck a cat's tail in an electrical socket with all the metal shavings on the plug. This was true for both a previous 1500 and my current 2500. I haven't had any noise from my 2500 Tcase and it now has about 24K miles on it.
I have had the same noise on my '16 since day one. Plan on changing out the T-case oil when it warms up.
Weird because my '03 was always silent in 4WD
Edited by madcowranch
As I indicated earlier, there is a TSB out for at least my 2012 for tcase noise...it sounds like a pinion bearing (coast sounds different from load). Under load you would think either the front end or the transfercase had a bearing about to implode. I don't use 4wd often, but when I do its for miles and miles of snow covered roads (which makes this noise particularly annoying) or towing/hauling heavy offroad (think cutting firewood).
I have nearly 100k on my 2012 and have had it in three times for the noise...the first was the TSB acknowledging the noise, the next was a TSB for a fix, and the last was a TSB stating the fix didn't work and there was no other plans to address the issue.
You can probably look those up, and see if they cover your truck.
I gave up after try number three, the fluid in the front differential and the transfercase look fine, I get very little wear metal on the magnets, and the noise hasn't gotten worse in that time. I'm not going to worry about it.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
