Stock Flashing 3rd Break Light?
Confirmed dealer add on. One of these weekends I'll have to pull that out. Not a fan of the pulsing 3rd brake light, even if it may provide a minor advanced warning to cars behind me.
Thanks everyone!
if you yank it out shoot me a pm with a price. Please note which wires it was hooked to.
If I lived in a metro area I would probably have a different opinion. But, in middle TN there isn't enough traffic for the potential safety benefit to override the fact I don't like the look of it.
I agree that on a motorcycle it is a different story. My R1 has a similar feature.
If I get around to pulling it out I will be sure to PM you.
I couldn't care less if it annoy someone behind me, honestly the a##hole in me smiles thinking about it doing so. I care more about getting that stupid moron off their phone long enough to not rear end me. Won't cause damage to me, but waiting around 2-5 hours for FHP to show up just so you can get the traffic accident report and go home is quite a PITA though. I toy with the idea of adding this to my truck, didn't know it was an added feature, thought it was computer controlled. I know a few of the loaners the dealer has given me has had a sticker saying something about the vehicle having this feature but those were tiny car like things.
*edit*
I think some of our UPS package cars have this "feature" too.
It gets your attention for sure. I like it but I too would like to see some sort of logic in the thing so if you're in stop and go traffic it doesn't keep going.
  • 2 months later...
Thanks everyone!
Sounds like something the dealer did and charged you for. Did you notice it on the paperwork?
For me, I think all this add on lighting is getting out control. Most are a distraction to other drivers. Front or rear.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
