Blower motor doesn't work on high
My 03 had the blower stop working on the high setting (5) about a year ago. I finally got around to replacing the resistor and it still didnt work on 5. So i ordered another new resistor and a harness pigtail and it still doesnt work on high.
When i switch it to 5 the blower turns off and i can hear the resistor make click noise. Like a switch is turning off. I've also checked the 40 amp HVAC dose under the hood and it's good. Ideas?
Blower motor resistor. Very common $20 part. Installs on passenger side up behind glove box. 45 minute install. Have done several. Tutorial on YouTube on the 1aauto site.
Be sure to check the wiring and connector while in there because they have been known to melt/burn with resistor failure.
You haven't specified which HVAC control unit you have but since these came mainly with the manual HVAC with 2 sliders like this one ( most common ).
High speed bypasses the resistor network and sends B+ directly to motor through a relay. If you hear the relay click this means the high speed command has made it through the resistor network. Chances are you have burnt relay contacts, but since new resistor network comes with new relay you can eliminate this as the problem.
Screenshot%202017-01-23%2010.35.23_zpsdu
If it's not the relay, You are probably going to find pin ( F ) burnt in the back or the female contact in the plug. For reference this pin is the one beside the missing pin.
It could also be the switch itself of course!!! Easy to take apart and find out or just replace the whole unit if you have a junkyard near by.
Thank you for the detailed post. What your saying makes sense but since I have a new resistor and a new end that plugs into it i don't see how that could be the issue.
The only thing is my plug doesn't look like the one you posted. It's flat with 6 connectors in a row. And yes I've got the manual dual temp like the first picture you posted
The connector I posted is not at the resistor network end it is at the HVAC module end. Snap the cluster bezel out and remove your HVAC module and check both connectors pin ''F'' next to missing pin ''E''. If they look nice and clean then I assume the actual switch is faulty in the module. If you want me to show you how it comes apart let me know. ( The switch I mean )
Yes the connector behind the HVAC module. What the hell, I'm retired and got nothing better to do, so for the benefit of others on this forum, here's how that switch comes apart.
First undo the two 7/32 screws ( They may be 6mm but the 7/32 socket worked )
Leaves you with this...
Then with a pry tool release the 3 clips...
Here's the high speed contact....
This is the wiper, you know it's good if other speeds work.
this is the switch seat, only thing there is the spring loaded ball to give you the clicks between positions.
Now yours will be full of dielectric grease which I removed for graphic purposes. Thank You if this helps anybody.
Just another idea if you are unable to get your problem resolved. I had a blower motor do pretty much the same thing on a 96 K1500. It would operate intermittent but would not run on the high speed setting. Checked all the wiring and resistors as you have done. Finally got fed up and put a new blower in it. Problem solved and been working ever since.
So I worked on it a little more today. Put a volatage meter on the wires that go to the resistor. On each setting the respective wire would be 12v. Except the red wire for the high speed. I was only getting 3v on that wire. I changed the fuse under the hood anyway and no change. So my issue is somewhere between the fuse under the hood and where that wire comes out to plug into the resistor. Any ideas where there could be a connection I could check on that wire?
I had even coloured the wire red in question for you so you would know which was which. lol It even says red on the diagram. I would think ''C4'' of the junction block would be a good place to start.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
