Can Someone give me the 411 on Lowering the Rear of my 2500hd?
Does anyone have any pictures of the bed seam and shackle after the install? Just picked up a new truck and this seems like what I’d like to do.
  • Replies 36
It's pretty obvious once you get under there and look.  It's hard to cut the seam and not have molten filings rain down on you but it has to be done.  End result is good though.
  • 1 month later...
For all you guys cutting the pinch welds or bending them over can you just loosen the bed bolts and lift up bed enough to get bolt out? This works for the 1500 guys just wondering if there is something different with the 2500's.
  • 3 months later...
You really like working a project don't you!
But seriously, I was getting a magnaflo muffler put on at a local independent shop near me, so I had them do the McGaughy's at the same time.  My time is limited and when I am getting something done it is sometimes more cost / time effective to have the shop do something else.
I have had the McGaughy's 2" drop shackles in for almost 4 years in my 2015.  Would not do it any other way.  I also installed a set of SumoSprings to replace the axle bump stops.  Can throw over a ton of material in the back and it still is level.  With the 2" drop shackles installed, the SumoSprings rest right on the axle when the pickup is empty.   Nice progressive support once I start loading up the bed.   Smooth ride.
  • 2 months later...
Just got my McGaughy drop shackles installed yesterday. What a difference they make, not only bed accessibility but overall appearance as well. I went to a suspension shop and had them do it. I tried mounting them myself but had a heck of a time trying to get the new shackle in the hanger, so the money they charged me was well worth it. Has anyone had to replace the rear factory shocks due to the 2” drop, or is there enough room for them to compress while under load?
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,762 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
