Drivers side b-pillar Line output converter?
Goinovr
I ended up running all my wire for my sub down the drivers side and was going to tap into the speaker wires for the rear at the B-pillar. Trouble is the only colors that seem to match the diagrams I've found are only for the drivers-rear. I was wondering if anyone had tapped into the system in the same area or if I should just tap in somewhere else or if I just need to look further up the harness for the wires.
Speaker wire colors for non-Bose:
Left Front Speaker (+/-) // blue - brown/blue // radio, green 16 pin plug, pins 1 - 9
Right Front Speaker (+/-) // yellow - yellow/black // radio, green 16 pin plug, pins 2 - 10
Left Rear Speaker (+/-) // green - green/black // radio, green 16 pin plug, pins 3 - 11
Right Rear Speaker (+/-) // white - blue/black // radio, green 16 pin plug, pins 4 - 12
I tapped into the rear door speaker wires where they meet the rear door jam in the b-pillars. Green and Green/Black on left rear, White and Blue/Black on right rear.
Thanks. this is exactly where I ran my rca's for my LOC. I was looking for a white/blue and a blue/black. Didn't want to tap into wires and have my window no longer roll up or down. haha.
Lack of sleep but it finally dawned on me that you're saying the left and right are on either side of the truck and not together on the driver side b pillar. Hmm. May have to get creative for the other channel.
I was going to run my amp bridged into my sub.
Correct. One pair on each side. You could run each pair from each pillar to the amp, but if your plan is to bridge the amp then a single input should suffice. Typically most sub-bass frequency content is mono anyway, so I doubt that you would notice a difference by using just a left or right signal.
FYI, be careful where you grab the signal from. The truck has crossovers split throughout the cab. You have 4 signals leaving the headunit. The mids have a crossover at some point throughout the dash so you would not want to use the signal at the dash speakers. Not sure about the rear doors but I would tap behind the headunit for a solid full signal. Ideally, you would want a full front and full rear signal and then sum that up as 50% full front signal and 50% full rear signal to get as much information from the system as possible but if your LOC does not have summing, then tapping the rear signal wires would be fine.
  • 3 years later...
I'm still confused. I have 2016 Silverado lt. I have the 16 pin connector but I see no white cable. I'm just wanting to run 1 amp for bass. I want to connect from the dash board please give me easy instructions
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
