Headlight Comparison
Does anyone make a headlight unit for the 2014/15 that has projectors designed for LED bulbs? All the aftermarket ones I can find are made for halogen bulbs.
And yes I know the 2016 units will fit but I don't like how they look
  • Replies 40
I went from a 2015 Sierra w/ halogen projectors to a 2017 w/ LED projectors.. there is no comparison between the two. The LEDs are amazing especially when you hit the high beams..
These should be standard on all trim levels!
  • 2 months later...
So I'm going from a 2014 Sierra with currently installed DDM 40 watt LED bulbs(very hotspotted) to a 2017 Silverado with the OEM HID, is it true the projectors are much better than when they first came out in 2014, cause I went from a 2012 Kia Sorrento to my 2014 Sierra and couldn't believe how bad the SIerra projectors were in terms or width coverage.
id like to upgrade my reflectors on my 14 but the price for projectors are just nutty.
I was going to do that as well but after installing HID headlights and Morimoto LED fogs I don't find it necessary. Much better light pattern on the stock projectors with HID than LED
2015 with projectors and LED bulbs. Love em and super bright. Had HID for a while and these are much better option. no ballasts, no warm up, cleaner install.
Mfbearded what leds did you use and do you have a link
I 2nd this
I 2nd this
Tagging him so he gets a notification as I am curious as well.
I went with the Recons with HID, also have the Morimoto fogs. very bright. I recommend the recon lighting to all if you like that blacked out look.
