I guess my truck is feeling its age, 03 SIlverado 4x4, 42,000 miles.
FOB stopped opening doors, just out of the blue
so I replaced batteries with some I knew were good, no soap.
took fob to orielly's and according to their counter machine they are transmitting fine.
So I did the following per a download on the WWW for an 03 SIlverado: Several times.
If Your Silverado Doesn't Have a Vehicle Information Center (pre-2007)
Step 1: Sit in the vehicle with all the doors closed and unlocked. Insert the key into the ignition. Do not turn the key until directed.
Step 2: Press and hold the Unlock button on the driver's side door. You will hear the locks make two clunking noises, indicating they have completed an unlock/lock cycle. Continue to hold down the Unlock button.
Step 3: While holding down the Unlock button, turn the key to the accessory power position then back to the off position. Repeat turning the key from the accessory power position to the off position for a total of two cycles.
Step 4: Release the Unlock button. Your Silverado will automatically cycle the locks as it did in Step 2.
Step 5: Simultaneously hold down the Lock and Unlock buttons on your fob for 15 seconds.
Step 6: Program any additional remotes for repeating Step 6 for each remote. Up to four remotes can be programmed.
Step 7: Exit programming mode by starting your Silverado. Turn off the vehicle and test your remotes.
AGAIN No Soap
Does anyone know if the sync instructions are valid for 03 Silverdo? If not, where can I find the correct?
OR
is this a dealer or lock smith issue?
thanks folks
That is the right procedure. Does your truck go into programming mode after step 4? These FOBs are a bit odd, they will lose half the protocol after a 12 years. I sell and program lots of these every year. I check the FOB and it transmits but doesn't work on the truck. A good one sends 4 streams of code where these when they fail only send 2. I will make a little video and post it here.
You US guys can get these for cheap on amazon.com and these are of better quality than OEM.
https://www.amazon.com/KeylessOption-Keyless-Remote-Control-Replacement/dp/B00KTIAREM/ref=sr_1_1?ie=UTF8&qid=1486069494&sr=8-1&keywords=gm+2003+fob
Well you are a wealth of info on all fronts;
If you mean does it "Your Silverado will automatically cycle the locks as it did in Step 2"..........nope, does nothing. Locks do not budge, everything quiet.
Believe I will wait and see your video...
thanks Coby
so maybe Orielly's counter machine lights up with just two streams of code
Edited by GreasyHands
Here's that little video if it will work... The good FOB is on the left and the bad one is on the right even though it still transmits it's a dud.
Edited by Coby7
If it doesn't cycle the locks in step 4 then you have an other problem. Maybe the fuse for the RCDLR is burnt. Let me see see if I can identify it.
Well that video was straight forward and sums it up. I guess it could be the same situation at Orielly's when I tested them there. They just had a little receiver at the counter with a couple of lights on it. Interesting
Looks like I have another problem alright, or maybe two. The one fob has not operated for a long time. This other fob just stopped a few days ago
Boy the little challenges I have experienced with this truck. It runs well, but just a laundry list of little things. Intermediate steering shaft, instrument cluster, tow haul switch, over cab lights never connected, parasitic drain, rotors, rusted brake lines and fuel lines......when I got the truck it had 28k miles and was under coated with periodic touch ups. My brother in law has a 03 nearly the same and he did have intermediate steering shaft, but nothing else......
Did you say you replaced batteries in both FOBs at the same time? If yes then you need to do a resynchronisation. High lighted that in red here.
Remote Keyless Entry (RKE) System Operation
If your vehicle has this feature, you can lock and unlock your doors from about 3 feet (1 m) up to 30 feet (9 m) away using the remote keyless entry transmitter supplied with your vehicle.
UNLOCK: Pressing this button once will unlock the driver's door. The parking lamps will flash and the interior lights will come on. The ground illumination lamps will come on. Pressing UNLOCK again within three seconds will cause the remaining doors to unlock. The parking lamps will flash and the interior lights will come on.
LOCK: Pressing this button once will lock all of the doors. Wait one second, then press LOCK again and the horn will chirp.
Operating the keyless entry transmitter may interact with the theft-deterrent system. See Content Theft-Deterrent .
Remote Alarm
When the panic button with the horn symbol on the keyless entry transmitter is pressed, the horn will sound and the headlamps and taillamps will flash for up to 30 seconds. This can be turned off by pressing the panic button again, waiting for 30 seconds, or starting the vehicle.
Matching Transmitter(s) to Your Vehicle
Each remote keyless entry transmitter is coded to prevent another transmitter from unlocking your vehicle. If a transmitter is lost or stolen, a replacement can be purchased through your dealer. Remember to bring any remaining transmitters with you when you go to your dealer. When the dealer matches the replacement transmitter to your vehicle, any remaining transmitters must also be matched. Once your dealer has coded the new transmitter, the lost transmitter will not unlock your vehicle. Each vehicle can have a maximum of four transmitters matched to it.
Battery Replacement
Under normal use, the battery in your remote keyless entry transmitter should last about two years.
You can tell the battery is weak if the transmitter won't work at the normal range in any location. If you have to get close to your vehicle before the transmitter works, it's probably time to change the battery.
Notice: When replacing the battery, do not touch any of the circuitry on the transmitter. Static from your body could damage the transmitter.
To replace the battery in the keyless entry transmitter do the following:
Insert a dime, or similar object, in the slot between the covers of the transmitter housing near the key ring hole. Remove the bottom by twisting the dime.
Remove and replace the battery with a three-volt CR2032 or equivalent battery, positive (+) side up.
Align the covers and snap them together.
Resynchronize the transmitter.
Check the operation of the transmitter.
Resynchronization
Resynchronization may be necessary due to the security method used by this system. The transmitter does not send the same signal twice to the receiver. The receiver will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter.
To resynchronize your transmitter, stand close to your vehicle and press and hold the LOCK and UNLOCK buttons on the transmitter at the same time for 15 seconds. The door locks should cycle to confirm synchronization. If the locks do not cycle, see your dealer for service.
Edited by Coby7
Also the procedure you have fails to mention that you have a limited time to do this, once you insert the key and press and hold the unlock button you only have like 10-15 seconds to cycle the ignition twice or it will not work. Here is the written procedure I use and it works every time. Make sure all doors are unlocked before you start.
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
Edited by Coby7
I did replace batteries at the same time, but one fob previously replaced long ago and was inop then to now. Several years past.
Locks cycled per # 9, but so soap on fobs.
Also, followed instructions in red too the letter, so soap
Time to write amazon an order?????? What ya think?
thanks a ton
If door locks cycled that means your RCDLR went into programming mode. You then have to hold the lock and unlock buttons for sometimes almost 30 seconds for each FOB.
Sorry Coby7, I wrote an incomplete response. I indeed held the unlock and lock buttons on the fob for at least 30 seconds, followed each step per your instructions.. No soap.
I can try again tomorrow to ensure no miscues, but I followed your instructions to the T on the sync as well.
If the relay you stated is working then maybe the fob just gave up the ghost..its nearly 15 years old. Like I say, one has not worked for years, the other stopped just a couple of days ago.
your thoughts, and thanks
Sounds like the RCDLR is bad. IE the Passenger Door Switch.
You can find them pretty cheap on ebay just make sure if you have TPMS you get the correct PDM RCDLR
PDM US RFA = Non TPMS
PDM US RFA TPM = TPMS
Okay, I think you have proven that your FOBs have failed just order a new one and try programming it. Cheapest route for now.
We will know in a few days, Ordered!
Will report back. thanks again
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
