So I know we all have the shakes when it comes to our trucks, but I have been experiencing a new "feature".
I'll be driving down the highway around between 65-80mph depending on highway and traffic and get a surging or pulsing feeling. It almost feels like the transmission is slipping, or it's knocking itself in and out of overdrive. The RPMs do not jump and it's not when it shifts from V4 to V8.
Does not seem to matter if cruise is set or not, and will happen multiple times, sometimes consistently every 45 seconds (rough numbers). Just trying to say it's not a one time deal while I'm driving.
Any ideas?
The first thing I would do is disconnect the battery let it sit for 10 minutes and then drive it again for a week and see if it comes back.
The last 6 GM's I have had ran on this LANBUS system and they all need a disconnect ever once and a while to start behaving again.
IF it comes back then you most likely are having an issue.
Thanks BBS. funny you mentioned that. I had to do that last week because MyLink crapped out on me and disconnecting the battery, (along with the fuse) was a supposed "reset" for it. Might not hurt to attempt it again though to see what happens.
Each time I had this problem I discovered a spark plug wire disconnected. First was the No. 1 cyl. Second was the No. 5. Not sure why they keep coming off the plug. Anyone else have this issue?
Interesting, i'll go to the garage and check that out. You would think that this would throw a code, did you happen to notice if yours had a code or not for like a cylinder misfire?
EFLine what year, engine and trans do you have?
The spark plug wire problem is common; I think there was a hole thread on that, and maybe even a TSB....I see if I can find it. There's a metal clip inside the boot of the spark plug wire where it connects to the spark plug, that metal clip becomes loose or even falls out, then the spark plug wire will not stay on the spark plug. If you have this problem you are supposed to replace the spark plug wire.
The surging is a separate problem I believe, especially depending on what year your truck is. There's been other posts/complaints about this. Apparently for the 2016-17 GM knows about this and is working on a reprogramming solution. The engineers said the trans needs more slip to be smooth but the trans engineer says more slip may cause damage to the transmission. (This info comes from another member who works at a dealer, I'll see if I can find that tread)
No codes. The engine light went on and off intermittently which might be related to the clip on the spark plug wire bouncing on and off of the plug. When I got home I plugged my code tester in and it gave me a 0305 code, (don't quote me on the code number, going from memory last night), and stated "cylinder 5 misfiring". It's easy to find just give the wire a little tug and you'll see it's just disconnected. I stopped at the GMC service dept today, told them about my two incidents and they said they had not heard of any issues with this. If you find that thread or TSB Bob I'd be interested in seeing that. Thx
Spark plug wires
http://www.gm-trucks.com/forums/topic/193036-loose-spark-plug-wire-heres-the-fix/
http://www.gm-trucks.com/forums/topic/175878-spark-plug-wires-coming-off/
Edited by 15_silverado
Hey guys, been out of the country and love all the great info and will read through this tonight. I really appreciate the links!
I will follow up with what I find.
Will have to investigate a tad more but it MIGHT be a pulsing or surging with V4 mode (AFM) that I didn't think was the case before... but coming back from the airport I watched it super close with the pulsing / surging and seemed to possibly correlate to when AFM kicked in. :dunno:
  • 4 years later...
Realize I'm bumping an old thread but I just purchased a used Yukon XL with the 6.2L and 62k miles and 10 speed transmission.  I noticed this 'pulsing' when driving it 7 hours back home on the highway 70-80mph.  This is my first time driving the 6.2L.  Did you ever find a fix for your issue?  Is this a common problem?  As the OP mentioned, feels like the transmission is slipping...
    • Well, I received a message from the dealer...
    • The no sound problem is the audio amplifier. The audio amp has a heatsoak issue in some circuitry which causes it to miss the wakeup handhake. If it doesn't respond within a certain time parameter, then you get no sound. I brought it in and had the software update, but after further testing the tech made the call for a new audio amplifer. The software update I belive gives more time for the amp to respond, but if the amp is defective then you can still get no audio at times. After the update it went 12 days before no sound. After doing some research, apparently the fix is a new (updated) audio amplifer, the circuitry internally has been improved to better deal with heat. I had to wait 2 1/2 weeks because at the time, it was on backorder with no eta. Well the amp came in earlier this week. I had the amp and programming work done today. After picking it up I stopped at a few places, and whenever I started my truck, the audio was on instantly, so whatever they did it appears to work because it's never had sound that quickly......Hope this helps
    • Make sure the latch mechanism is properly greased. Look at the catch for fresh marks/scratches. And see if it has moved a little, too.
    • I have the 18" black mutilspoke wheels that came with my truck. I like them as they are very subdued and look good with the 295/70's    I am sure that the next set of wheels I get will be some after market all black wheels. Or maybe some AT4X wheels.
    • Interesting question which you partly answered in the word 'potentially'. I think that is going to be a 'point of reference' inquiry. What are the touchstones?    This will sound petty but it is the main source of end fighting in threads on this topic. Define a motors "Life". Think about the various arguments that have been entertained on these pages in that very argument.    I can only speak from my viewpoint. Engine "Life" in my world is defined by power cylinder integrity. For the majority of engines it is the bore/ring interface that quits first. Loss of seal. Oil consumption and loss of power. Most Pro motor builders would agree and there is a good deal of information on using "Leak Down" as a primary indicator of bore integrity. At home a compression test is more the thing. If we can agree on that then I think CC Jensen has done its homework and I'd find it valid.    Now by my own definition, Dizzy, wife's Ecotec 2.4 I-4 has been dead since about 80K miles. And yet we have logged over 200K miles more on it. "Life" and "Usefulness" are therefore independent.      I know a mature fella right now who has just hit 300K on a Mitsubishi 3A92 NA MPFI motor and has done compression test every 100K. It was 205 psi after break in and is now about 195 and still even. He uses shelf oil but good filters and adheres to a 3K mile OCI. He even do UOA's on each of them for the first 50K.      I also know a fleet mechanic with that same motor that gets 300 to 500 K out of them but the are oil using, wristpin sloppy, skirt slapping motors. He ran one with a piston pin so loose the piston was bouncing off the cylinder head for about 20K miles before he called TOD. Both of them claim success.
