Lets Play Guess than noise
warhead2002
No, dealers are doing as little as possible. If they don't see a code thrown or have an obvious TSB issue, they won't look into it. Nobody is going to pay a tech to troubleshoot a knock/tick until the source of thr problem is obvious and GM is footing the bill. It's common acorss the auto industry. Google "Coyote 5.0 knock" and see how many obnoxiously loud 5.0's actually get warrantied for an unidentified knock, despite clearly being a mechanical issue. The answer is not many.
Ha, this happened to my 5.0, Ford said it was normal. It sounded a lot like the OP's video.
Yeah. They told me with out a code there is nothing they can do. My friend has the sierra and his makes that noise. But not as loud. And thegeek. Im with you on this one. It soulds like irs coming from the torque converter area. That is where the noise is centered from.
the noise is coming from the torque converter area. any ideas on hiding the noise since i cant get it fixed.
have you called GM and complained and if so keep calling keep going to the dealer talk to the general manager at the dealer don't give up make it where they hate to see you come in the door they will fix it
  • 3 weeks later...
Bad lifter, or torque converter! I'm betting on the converter being sloppy and unbalanced.
Start an open dialogue with 1-800 GM first! Then have them inspect those areas for known tsb and finallt an inspection.
Good luck
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 399 Guests (See full list)
