2017 1500 POWER FOLD Tow Mirrors
Ok Guys,
I did quite a bit of google searching, searching this forum and calling every dealer in my area. I have had many different answers and I am super confused.
I just picked up a 2017 GMC Sierra 1500 Denali Ultimate and need to install Power Folding Tow Mirrors. I know it was possible on the 2015 year model.
Today I was told 3 different answers from 3 different dealerships:
#1 it is only possible on the 2015 not the 2017 ?
#2 It is possible with the 2017 3500 Denali Power folding mirrors, harness & BCM Programming but not sure if this works on a 17.
#3 They had no idea, said power fold just isnt an option and wasnt ever supported / cant help
Im hoping the brilliant minds in this forum can save the day for me here and help me pin down what exactly I need and if BCM programming is needed if it is possible.
On my Denali regular mirrors I have Auto down when reverse, Puddle Lamp, Signal, Auto Dimming, Power adjust, Power Fold (im not sure about the temperature sensor ?? I have read a bunch of different things on that ?)
I would greatly appreciate any help and to clarify this is specific to the 2017 Year model.
Thank you all !!
As far as the temp sensor, just look under the passenger side mirrr by the puddle lamp to see if it has the sensor.
Correct. No sensor.
https://www.youtube.com/shared?ci=slMJmXtB1nY
As far as getting the mirrors to work, that shouldn't be an issue. Pgamboa on here is the master at these conversions. He will probably ask for a picture of the body side plug on your truck to verify if you have the pins present. Since you already have the dl3 mirrors, that shouldn't be a concern though. He has helped other members on here add the power folding tow mirrors as well with his custom harnesses. He makes it plug and play.
  • 1 month later...
old topic here but I just did this on my 17 Denali and it was pretty simple and everything works
yes, LH 23342727 RH 23342716 door harnesses.
  • 5 months later...
BLack denali canada were you able to install the power folding towing mirrors on your sierra?
I currently have a 2017 gmc sierra slt with power folding mirrors, i went to the dealership the other day but they told me that it was not possible to install those on my truck. Could you please help me and provide me with the mirror part number and harness part number as well. Thanks
Take a read through this tread. It should help you answer any questions you have.
http://www.gm-trucks.com/forums/index.php?/topic/198157-2014-2017:--DL8,-DL3,-Towing-Mirror-Upgrade--Mirrors-Explained
Sent from my SAMSUNG-SM-N920A using Tapatalk
yes the LH 84041609 and RH 84228894 this has the sensor for diesel engines but will work (and its cheaper) than the one without. you will need door harnesses though. check out this ebay item 112359077014 or http://www.ebay.com/itm/15-18-Silverado-Sierra-Chrome-POWER-FOLD-Camper-Trailer-Tow-Mirror-Pkg-OEM-GM-/112359077014?rd=1
GM also makes manual fold if you want to go that route. thanks!
  • 2 months later...
Resurrecting this thread. I'm buying my first Denali, and I want to add the power folding tow mirrors. 2017 Denali 1500
The dealer is telling me the mirrors won't power fold, but all other electronics will work. They're saying to order part 23372181, which is a package of two mirrors, I believe. Based on price alone, I assume this kit is different from the separate mirror and harness parts listed above. Perhaps these are the manual fold mirrors?
Thanks in advance for any help!
Message PGamboa on here.  Get to reading this thread.
