Xenon Depot HID Install '17 Silverado HD
revrnd
I've been running a Diode Dynamics kit for almost a year and my ballasts don't get hot. Warm yes but not hot enough to burn you or melt anything. Driver side ballast is mounted to the inner fender and passenger side ballast is mounted to the front header panel next to the air box. Can provide pictures if anyone needs ideas. My kit came with universal brackets and a heavy duty relay and harness.
Speaking of the airbox. Ain't it wonderful trying to line up the "peg" in the bottom of the airbox w/ the hole in the support bracket?
Yeah its difficult to see, I put Sil Glyde on the pegs to make it easier to "seat" the box.
Oh man those are bad ass! You're right about the tin foil brackets that came with my kit. Pretty weak, but so far are holding up. Nice work man.
Can you provide photos please , thank you
Thanks!
28 years as a tool & die maker comes in handy now and then. It was handier when I was working & I could 'prototype' parts @ work (see signature). You could 'work' w/ parts on a bench (not under the frame LOL).
Won't let me quote for some reason.
But Erwin, I watched an HID install video that mentioned the ring terminals and how they don't have enough room to fit properly on the actual terminal. All the guy did was clip the front of the ring to make it into more of a U type connector. Voila
The wonders of YouTube! As long as the lights turn on where they are supposed I'm good!
Sorry for the late reply, pics weren't the best quality. The relay on the driver side is for my light bar. This was mock up before all the wires were tied down and such.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
