Curious if anyone else can try this or has noticed this on their 2014-2016 5.3 Silverado.
When the truck is warm, after driving, if I rev the rpms to 2000 or similar in Park, and let my foot off the gas, they will drop suddenly but the then slowly at 1200 rpms down to idle.
ITs like the computer doesn't let the rpms drop evenly from 2000 to idle
Why would GM do this? What is the point?
Is it to prevent the engine and tranny from slamming in gear? OR some system protection to let the rpms fall fast but then slowly to protect the engine.
Thanks for your comments
Well I was getting an idle drop at stop lights that would make truck shake but then it would recover. So I was messing around one day and noticed this behavior while lightly revving it. What I am curious is if it is normal and other see this?
Completley normal and part of the fly by wire Throttle Actuated Control (TAC) programming. They just don't want to slam the throttle blade shut as on these there is no Idle Air Control (IAC) on the TAC equipped vehicles. On older vehicles the throttle blade was connected to the gas pedal via a cable and had a set screw adjusted to just slightly open the butterfly. The idle was controlled by an IAC which was a stepper motor with a pintle (pointy shaped tip) on it that would extend and retract in a corresponding orifice that allowed air to bypass the throttle blade. When you stepped on the gas the IAC would lift off it's seat to "catch" the idle on the way back down as the throttle was released. Because the sizing on the orifice was about as big as your pinky finger it could respond pretty quickly. If the valve was seated all the way in not bypassing any air the engine would idle pretty low usually about 200-300 below what the computer would target, if it was fully open with the throttle blade closed it would idle about somewhere about 2000 or so. That gave the computer a pretty sensitive and far ranging idle control. On TAC vehicles the position of the throttle blade dictates minimum airflow and idle speed. If you think about how the area increases as the throttle blade is opened it changes pretty drastically close to where the blade sits at normal idle speeds. They slow down its closing close to idle to make sure the vehicle doesn't stall. It happens while driving also but not as noticeable as when it is being revved with no load.
Would you be willing to see if yours does similar?
[Video]
[/Video]
Any way to reprogram this behavior? Something that can be done with tuning?
Did you ever find a solution to the idle drop? My truck is doing the same thing at stop lights and it makes the truck shake then recover just like yours.
No I didn't. next Thursday I am dropping it off for the service manager to drive for a day. Feels like when the idle drops the truck is going to stall and die. I hate that I take care of this thing and I amgetting plagued with this dumb stuff.
Lol i know what you mean, my second vehicle was a civic. I beat the living shit out of that car, it lived at red line for 200k . Only thing it needed was gas and an alternator.
  • 6 years later...
Did you finally get it figured out? Im having that issue now.
    nolankd
    nolankd
  • Who's Online   2 Members, 1 Anonymous, 438 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
