2015 Silverado 1500, 50k miles...Red light came on my Onstar and my dash compass started by giving me a CAL code, but within a couple days compass went blank. Dealership has it now and just notified me that their code reader says it’s the module that operates things like the compass, blondestar, etc. ($600-$700+ repair).
Although my 5 year/100k powertrain warranty is still in effect, the 3 year/36k bits and pieces and everything else warranty that would have covered this is sadly done. They originally thought antenna leak as well, but that was not the case on mine. Apparently the antenna issue is more prevalent on the color matched ones, and not the black fin style.
I’ve got an escalated case in with GM, and am hoping that as a loyal Chevy owner through 30 years and 7 vehicles that they’ll do right by me. That being said, the Onstar folks were great... credited me the two months this has been inoperable and is offering me a better rate on my monthly service with them if GM will step up and get that module replaced for me. Fingers crossed.
  • 1 month later...
2016 Suburban, 32,000 miles same GPS problem noted above. Super frustrated. Dealership wants to replace antenna for $400. Obviously, a known issue for GM - why aren't there issuing a recall/repair program?
  • 6 months later...
Same issue with my 2017 Yukon. Josh mentioned that he disconnected the rear view mirror wire and then plug it back in and the gps worked. Does any one know which pluge that is? I have not found any water comming out of the antenna, but I live in the desert and it probably got there at a car wash and then dried out.
  • 2 months later...
The antenna and GPS problem is common on GMC.  I have a 2015 Sierra 1500 Denali and the GPS (compass too) failed about a month ago.  The problem I had was a design flaw by GMC.  The weep hole was on the wrong side of the antenna.  It took mine about 5 y rs to fail.  Asked my dealer to look into it during an oil change and I was informed that the check would cost $130, which astonished me.  Through this website and other resources, I found out the likely problem and cure for free. My dealer should have known anyway and been able to identify for free.  Anyway, went to my favorite body shop and they ordered the new part and installed yesterday.  It is a plug and play item.  The new antenna took about 1 block to recalibrate and I am back to normal.  Part was about $130 and installation was $130 for a total of $260 and the weep hole is on the downslope where it belongs.  I did not want to dig into the headliner so paid a pro to do that, however, if you are confident you can repair on your own.  GMC should be replacing these when they fail.  I will not be returning to my dealer for service.
  • 2 months later...
2014 terrain display turns off randomly and controls don’t work intermittently.  This has been happening now for over a month (maybe more).  Doesn’t seem to be related to shock from bumping or anything of the sort.  Navigation won’t even engage, rather stays on the “initializing” screen.  Very frustrating and would like to know what’s going on
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
