After about a year the GPS on my 2016 quit working. A few days before I was waxing the top and the metal is so thin that it flexed around the GPS antenna and water ran out from under seal. It hasn't leaked yet but I suppose that's next. Dealer visit next week.
do you have an update from the dealer visit?
Had to cancel appointment, maybe this week.
OK, dealer visit 3/9/17 update. The dealer tech found "open in roof mounted hi frequency antenna" after "computer systems test". Ordered new antenna.
While waxing my truck I noted water coming from under the roof seal. It fits tight but the flimsy top lets the metal flex with moderate pressure. The day after the visit my GPS started working again. I think I got the water out by pressing on the top until it quit weeping. I assume this was creating a short while wet.
Funny-I threw this theory at the Service Writer but they ignored this and likely have ordered an unneeded part. I didn't contact them again because this will at least get them to look under the seal. I'll discuss this again when I go back next week for replacement. Now if they plan to remove the headliner I'll reconsider.....
There are 2 seals on these antennas . The outer one with a vent on the upper side (should on the lower side for drainage) that doesn't seal out much. Then there is an inner seal that should seal the hole in the roof. We have replace a bunch of these for leaking but not so much for loss of gps. Talk to the tech or SM to see if they will add a little silicone sealer to help seal it. Water that gets beyond the outer seal shouldn't be a huge problem if the inner seal is good. See more gps issues with the Tahoe/Suburban antennas. There is also a spliter under the defrost grill that has been known to fail on a few. Only if you have on board nav (I06). Splits the gps signal for the gps/nav and onstar. The head liner will have to be lowered along the windshield and left 'A' pillar area but not "removed"
Edited by tbarn
Thanks tbarn, an informed and helpful reply. When I got my paperwork and read the Service Writers notes it was nothing like what I reported.
Hello Ron.S,
We’re sorry to hear your Sierra’s GPS is misbehaving. You’re welcome to send us a private message, if you’d like us to reach out to your dealer on your behalf.
Kindest regards,
Anthony
GM Customer Care
  • Thanks 1
  • 6 months later...
Water intrusion is a known problem. Mine had to replaced this year.
Condition/Concern
A customer may comment they have one of more of the following symptoms:
The issue will usually be accompanied by a DTC (B2462-02, B2462-04, B2470-02, B2470-04, B125C-01, B125C-02, or B125C-04 ).
Note: This recommendation only applies to vehicles equipped with the high frequency “painted” antenna assembly after built before the dates listed.
Engineering has identified an issue of water intrusion into the body of the antenna assembly which can ultimately travel down the wiring pigtail into the vehicle.
There have also been cases of water leaks from underneath the antenna at the roof panel opening. Inspect the roof sheet metal to ensure there is no deformation at or near the antenna pass-thru opening
If the antenna performance concerns outlined and/or one of the water leak concerns are encountered, replace the antenna ensuring to use the latest antenna part number available from CCA parts without removing the cover from the base.
Important: The painted antenna cover is NOT intended to be removed. Do Not remove the antenna cover from the antenna base, as this may compromise the sealing performance of the new part.
Note: DO NOT use and any form of Sealants on the replacement antennacover, seals or gaskets.
Edited by elcamino
I had the same problem of no GPS. I took the god antenna out and opened it up and found some moisture on the inside. I dried it out and put it back together and that still didnt fix it. I noticed the green light was out at the Onstar buttons, also. So I unplugged the connector for the rear view mirror and plugged it back in. That fixed my no GPS issue and my Onstar green light came back on.
  • 5 months later...
Ok, I have a 2016 Yukon XL  Denali, and after having the signal disappear a couple times in 2017, now I have the red light on my ONSTAR mirror and my GPS says I am 50 miles away and can not locate me. I called GM and asked about the recall 15155 and they said my vin number was not part of that recall. The only thing I could do is have my case escalated for the time being and I now have a 48hr wait to see if a supervisor can investigate the matter. I told the representative that I was experiencing similar issues as mentioned in the service bulletin, except I haven't seen any water inside the car. She said then it is not the same issue then.
So after I got off the phone I went outside and inspected the antenna. I thought well maybe it doesn't have a tight seal to the roof? As soon as I started inspecting the rubber seal and nudged it with my fingers a decent amount of water came out. There is a weep hole in the rubber but it is on the back (high side). The water appeared to be pooling in the front. (the lowest point).
We have a 2000 Tahoe with approx 250K miles on it, and the thing runs like a champ. The LS motor is what sold me.  I purposely purchased this car a year after it was released so they would have worked out all the bugs. Between the the roof bow/noise issue, and some other things, I think they figured it out by the time we purchased ours. I have been really happy with this vehicle so far. The 6.2L LS and 8 speed transmission, with the MRC has been as good as expected. Even getting on average about 17-18 MPG around town, and 22 MPG on the freeway. I hope GM will take care of this issue with the antenna, so we can continue on with it for many years to come.
  • 1 year later...
So I took my 2016 GMC Sierra Denali in since my GPS quit working suddenly the dealership just called and said I need to replace my antenna with a new improved antenna which in my eyes means that GM has issues with there OEM antenna. The new part is $150 and they say the labor is $400 that seems excessive to me seeing if anyone has had the same thing told to them.
  • 1 month later...
Yes same problem  2015 highcountry told me corrosion and needed new antenna 400 dollars. I had a headliner leak a year ago a few drips left corner. Never fixed it
Same issue. I own a 2016 Sierra Denali 6.2 and just bought it used from motor werks Cadillac in Barrington il. And they told me the same thing. $600 dollar repair. And said that the bumper to bumper warranty was expired, which it is. But come on with only 30k and I have a leak and the GPS is not working. I hope they fixed the problem and design better more thoughtful parts. it is an expensive truck. And to have this problems like this I think is unacceptable. thanks and GM DO SOMETHING ABOUT IT!
Edited by Huazcar lozano
Misspell
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
