5.3 made in...
How do you tell where the 5.3 is made - is it in the engine serial number? I know they are made in Tonawanda, NY, Ramos, Mexico, and St Catharine's, Ontario, Canada, but how do you tell which plant supplied the engine? Just curious.
Engine identification can also be made through use of the Engine Traceability label (2) on the rear of the left cylinder head, or the Engine Traceability label (3) on the engine block as shown.
  1. Broadcast Code
  2. Machine Readable 2D Matrix
  3. VPPS Code
  4. Part Sequence Number
  5. Reserved use
  6. Broadcast Code
  7. Model year
  8. Julian Date
  9. Build Year
  10. Shift ID
  11. Plant IDGM
  12. Part Number
  13. Plant DUNS Number
  14. Sequence Number
  15. RPO/Engine Family Code
Bottom row of number/letter combinations on that label. The first two identify plant ID and shift ID. If its not on the head, its on the lower right of the engine block right behind the AC compressor.
build sheet will tell you.. .mine was plant G... mexico.... ,. there is a rep on here that if you send them your vin, they will send you your build sheet... i got mine within the day.
I would love to have a build sheet.
If you know where to send my vin, let me know. Thanks.
What was the identifier for that?
looking now guys.. hang tight
That is the RPO code for the plant that the truck was assembled in. That does not identify the engine source.
sorry man, i guess i miss understood you ... engine source?.. is that on the build sheet as well?...
My truck was built on Thanksgiving day.
Guess that means Mexico for me.
Plant G.
Is that considered an early build?
I have an 8 speed fyi...
He wants to know where the engine was built, not the truck.........
Thanks for supplying the info 15hdriver, so the 11th digit on the motor itself is where the motor was assembled, correct?
Plant G.
1500 Crew cabs made in Mexico - 6.2L made in Tonawanda, NY and St. Catharines, Ontario.
http://www.gmpowertrain.com/engines/docs/GMQD16CLC60_L86_Product%20PDF.pdf
http://www.gmpowertrain.com/product-overview.html
Any luck getting that middle head-rest installed?
I thought I read on here somewhere that early builds had 6 speeds etc... Was curious since mine was built in Nov 2016 etc...
My guy is looking in salvage yards I guess for a used part. Didn't seem to think he would have any issues.
He was running behind etc... said it would be a while.
Its the first two digits on the bottom row of the sticker. I will try and grab a shot of one of the labels if I can.
Thanks 15HDriver. Identifying where the truck is made is easy - I was curious about where the engine was made. Not that it matters, but I am curious.
I will look for the code on the label on the engine (like you mentioned in post #2), but how do I decipher the code? Is there a list of the codes and their meaning somewhere.?
