Dumped the eco-moose
Hello all-
I've had two Fords and liked them both quite a bit. That all ended when my 2012 half ton 3.5 eco burned a cat out at 80,800 purely because of their misfire/Intercooler moisture/ carbonized valve issue per my mechanic and ford would not even discuss it with me. 800 miles past the warranty and they washed their hands of it. Oh well- I am now the proud owner of the most beautiful truck I have known to exist (well maybe the 2017...) a black 2016 Silverado HIgh Country 4x4- I bought it this week so pardon the emotion as I'm in the honeymoon stage still! 6002 miles and got it right at my budget and what I thought was a good deal-(barely broke through 40k mark). I'm obsessed!
Welcome I would not expect too much from any piece of machinery designed and built by humans furd or gm lol. Good Luck with it man.
I sure do like the look of those 2017 GM HD duramax's with the hood scoop though......what is the worst that could happen?
Hello all-
Congrats man !!!
I had a '12 Ecoboost as well .. 75km / 47 miles the engine decided to grenade lol. Hole in the side of the block, no true cause from ford. New motor thankfully under warranty. When I got it back shifted like garbage but "that's how it's supposed to be" I was told lol.
Picked up a '17 Denali !! Loving it like you !!!
Let's see your new truck !!
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 496 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
