2017 1500 Radio not reading USB 3
Got new 17 all terrain yesterday. Loaded a new usb stick with music. I guess it doesnt like USB 3 sticks
stuck a old slow usb in and it works.
Both formated fat 32
So wasted $20 on the super short USB stick 3.0 speed. wanted the short one so it doesnt stick out of the port in truck. out of the way.
Retarded
don't know if this helps, but here is what the owners manual says,
USB Port (Base Radio
with Touchscreen)
Using the USB Port
The infotainment system can play
music or movies by connecting an
auxiliary device to the USB port.
USB Support
If equipped, the USB connector is in
the center stack below the climate
controls, and uses the USB 2.0
standard.
USB Supported Devices
. USB Flash Drives
. Portable USB Hard Drives
Not all iPods and USB drives are
compatible with the USB port.
Usually the sticks themselves are backwards compatible... you may have better luck with a different model or brand. Sometimes it happens that way. I wouldn't give up on 3 just yet.
