Power Steering Pulley's and Belt
Hi everyone
My Power Steering has been playing up for some time now and I have already ordered a new Power Steering Pump and would now like to change the Pulleys and Belt.
It is currently running on 2 Pulleys and a V shaped Belt.
I am now sure if I should change the Pulley Type and Belt from a V shaped one to a different one as I am not sure if it is a straight swap ?
Can someone also let me know what part numbers they are for both fo the Pulleys and the Belt please.
Thank you all :)
I have just removed the bottom Pulley and taken down the Part Number but am unable to trace down a replacement part as the item has become discontinued.
Can anyone help me find it.
GM Part No.: 10069912
shows as a crank pulley, v-belt is on the inside.
should be real easy to just go to one V.. if that is what you are doing?
the other choice is a junk yard, any gm v8
1982-88, see if it has got one.
Is that a serpentine on the outside? Not sure what you are fixing.
this site here gives models of gm that had it.
http://www.chevypartsprime.com/oem/chevrolet-10069912_pulley-asm-cr-shf.html
here is an ebay ad for years down the middle..but with 3V
http://www.ebay.com/itm/1985-86-87-88-Small-Block-Chevy-V-Belt-Crank-Pulley-/272534893016?hash=item3f745871d8:g:v5UAAOSw-0xYiqdc&vxp=mtr
I took in the impossible, ebay is a great place.. just got to find other labels for the same part. Not many use part numbers off junk pile. they go by year and engine.
