Steering stabilizer 2016+
Anyone installed a steering stabilizer on a 2016+ 2500hd yet? I know the 2016+ trucks don't have the bracket for a stabilizer like the 2011 to 2015.5 trucks had. I belive bds sells one with a bracket, but unsure where to mount it. Any help would be great! Running 35x12.5r20s and have a little bump steer now.
  • 3 weeks later...
I just received mine. Been working 84+ hrs a week and haven't had any free time to install. But once I do, I will let you guys know how it goes!
  • 2 years later...
I found that if you make sure you torque it to at least 90 ft lb (rivet nut) you will have a better chance with it holding. As well I ran a 1/2" starter tap through it before I tried to bolt the bracket on. The threads seem to distort when you squash the nut and then when you put the mounting bolt in it is hard to turn which makes the nut wheel in the frame hole. As well I have found that a bit of red locktite on the knurled part of the nut (outside) will help it hold. Shane
