Post Pics of your Shells/Toppers 2014+
Mine is a ARE Z series but I took a different route and had it Line-X instead of the usual color matching.
I know everyone prefers color match but I couldn't do it on this white truck, it was bland enough already so thought I would try something a bit different here.
This a is a 2017 AT.
  • Replies 51
You could probably tie that in real nice with some matte grey vinyl wrap decals or something !!
I'm kinda diggin the line-X cap
I think that looks sharp. If that were my truck I think I would also lineX the front and rear bumper to help balance the color out. I might do this on mine anyway to stop all the paint chips I am getting on the painted front bumper
ARE CX series. 4 clamps, but I don't think you could remove it by yourself.
6CC535F0-8D75-4961-8B89-935566A22457_zps
Topper looks great on ur truck!
in the market myself. looking for a cap to build a small camper in. raised bed etc.
I saw a post on that before. Looked pretty functional. My Leer has stiff support rods and a rotary center latch. That might be hard to operate from the inside. You might want to look at the older style window with a twist latch on each side.
You may also want to consider a mid-rise version of the brand you choose. Many manufacturers offer a topper that is 3-4 inches higher than their cab-high models. I would have chosen a mid-rise if I planned to sleep in the back of my truck.
My leer has the centre latch but just a single pull release inside. Brand new 2017 so maybe they changed it this year ?
I think mine is the same. I just noticed it's really hard to close the rear latch because the gas pistons are stiff. You would probably have to rig a pull rope or something to close it.
i considered it i just hate the look so much. so im thinking sense i have a bed rug already ill put small bed right on the rug and shelf on the side and rear. my head could lay under the rear shelf.
I agree that cab high canopies look the best. Some mid-rise versions like the Century High-C look pretty good, imo.
I had a Century brand on my last truck and was disappointed that the rear door hardware, hinges and bolts rusted badly after just one winter, about 8-months of use. Not to mention replacement parts were difficult to get and expensive. Took about 6 weeks for my dealer to get Century to send him the correct parts and then they would not warranty them for rust and corrosion. This A.R.E. has gone 2 winters now and not a sign of rust on anything.
Interesting. I have a Century on order and not pleased to read about the problems you experienced! I had a hard time choosing a cap as the popular brands in my price range appear very similar. The deciding factor for choosing Century was I was most impressed with my local canopy store and they promote Century. I felt that they would give me the best service if required. I will be diligent in watching for early signs of rust!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
