Google search
Go to www.google.com and type in "weapons of mass destruction" as your search term, then hit the "I'm Feeling Lucky" button (beside the google search
button).
Read the entire page that comes up. :)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
