Just wondering if anyone knows where i can get the correct pins and or pins and plug end for the Led harness that plugs in under the bed for the Factory bed rail lights?? Just got this all installed with an OEM harness. But the end that plugs into the junction box is a 6 pin oval plug. The one that cam on the harness is an 8pin oval? Im thinking i got the wrong harness number? Difference between 1500 and 2500HD maybe?
Would be quick and easy just to change out the plug end etc.
Thanks for any help!
I used two small spades, drilled out the plug. Give some slack so you can plug them in( I made mine snug) then once you slide the plug over, put a little RTV in the holes. Not too hard and cheap.
Sent from my LGLS992 using Tapatalk
GM changed the plug in 2016 (I have no idea why). There may also be a difference between 1500/2500HD but I know for sure even on the 1500's the plug changed. If you do a forum search there are some threads discussing the change.
Also, mine is a 2016 3500HD for reference.
Yep thats just like mine. Have you noticed that the bed lights go out when you apply the brakes?? While in reverse with the cargo lights on etc?
That sounds like a bad ground.
Check every thing and grounds are good. The lights go out completely when the brakes are applied. This harness only has ground and power. Located side buy just like the picture in the previous post. However the plug on the truck side does have 3 pins. One ground and 2 power? Maybe i should swap it out to the other pin?
So no one elses truck does this?
Thanks.
Edited by 2016HD
Could you tell me what side the power and grounds are on? referenced from the squeeze part of the plug? Thanks.
Installed the kit on my truck. The harness plugs into the bank of plugs under the spare tire. Remove spare tire and when looking you will see a dummy plug on the left facing towards the ground. Plug your wiring harness in there after dummy plug is removed. The lights work great especially with a tonneau cover on the bed.
Ive installed the kit. However the kit i received had the wrong plug end on it! I used the dummy plug and just Transferred the pins from the wrong plug to the dummy factory plug etc. However. There is 3 pins on the truck harness. I now have them working correctly. But the picture that was posted above is the wrong pin connection on my 16. On my truck the power and ground or opposite corners. Not directly above each other. They are working great now. But I wonder why there is a circuit tied into the brakes??
The bed lights and cargo light above the rear window will turn off whenever the truck is put in gear. This is by design and is controlled by the BCM. I hate it!
Hi,
I'm wanting to add aftermarket lights to my box as I've heard that the OEM ones aren't very bright however I was looking for an easy way to integrate them to the truck, What size of female connectors did you use to create your plug from the dummy cap?
Thanks
  • 3 months later...
Can you share the pin out if you happen to remember?
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 914 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
