I'm pretty sure this has been explored in the past. It requires flashing the truck, and I thought the eventual conclusion was that it's not possible.
It sure works nice......... Hauled a little rock today..........
:cool:
Yes, the new faceplate is available with the switch. And maybe i should brush up on my "search" skills...
Edited by wbfn/wykk
I was wondering the same thing cause I was given the factory harness with my truck for it
My understanding is that "factory harness" that came with our trucks is for an aftermarket brake controller. Is there anybody reading this who has successfully installed an oem brake controller in a truck that didn't originally come with one?
From what others have stated it is not possible to add the JL1 factory trailer brake controller if the truck does not come with it. If you want a quality brake controller get a Tekonsha P3 and put it in the pocket where OE one goes. Here is a picture
http://www.gm-trucks.com/forums/uploads/monthly_12_2015/post-127843-0-77143200-1448998330.jpg
Edited by Lgetz
I don't know about you, but the placement of that brake controller is just hideous and sticks way out. Under the dash would be a better spot.
  • Like 4
The dealer will not reprogram the BCM to support it. GM will not allow them access to the area they need to do it in.
You need to add an external one.
This has been discussed over and over and no one has pulled it off that I have seen.
May work for some but longer legged people might bang their knees with it. If I did more towing buying a truck with JL1 option is a no brainer. Right now it is a non issue.
May work for some but longer legged people might bang their knees with it. ...........
X 2 - Banged my knees on a Prodigy for 10 years in my 2007.5 .......... Never again would I own a rig without a built in controller were it is up in a safer place for use. Same for back up camera..... makes hooking up sooooo much easier..........
Edited by Krusty
Pleany of people will hack the BCM for you. Sure it voids the truck warranty but it is all about what the Op wants.
    erickn520
    erickn520
  • Who's Online   2 Members, 0 Anonymous, 634 Guests (See full list)
