Black fog light trim
I decided to try my hand at vinyl wrapping the chrome trim around the fog lights on the wife's 2017 Midnight. I used matte black to try to blend in with the rest of the trim around the lights.
Before
F9DC8FE9-2256-4BAC-9D52-D21D6A12B12B_zps
After
A8ABE271-A9F0-4F46-8960-A9EC4B88C358_zps
BB6E4EA5-A75C-4C4A-A477-323A643F220F_zps
Looks awesome! Does the trim just pop out of place?
Got any info on the vinyl you used?
Thanks.
To remove it:
1. Remove the lower fender liner screws and fold the liner back to gain access to the fog light
2. There are tabs on the sides and bottom of the trim piece. Release them with your fingers and the whole bezel pops out.
3. Release the tabs holding the chrome to the bezel.
I used 3M matte black wrap vinyl. 1080 series I believe. Took about 10"x12" to wrap each. Heat gun or hair dryer is a must to get it to stretch enough.
Thanks.
To remove it:
Cool. Thanks I am gonna try doing this on mine. I have a heat gun. Although I have never done any sort of vinyl wrapping before....will be an experiment.
Where do you buy the 3M vinyl?
This was my first wrap job as well. Take your time and buy extra vinyl. I scrapped the first piece.
I bought my vinyl on Amazon. A 1ft x 5ft piece was less than $20.
Cool! Thanks dude.
Just bought some. Cost $12, shipped!
You're welcome. I just checked and it was 1080 wrap I used
Perfect, that's what I bought.
Hey these forums seem to be pretty dead. Have you joined Coloradofans.com? It's seems to be a little more lively over there.
I've been a member over there off & on since about 2005. I had a 2005 and 2007 Colorado.
So I got my vinyl the other day. I was gonna attempt doing this over the weekend, but ran out of time.
I have a question tho, So you take your 10x12 piece and drape it over the bezel. And it should just stick yea?
Do you have to cut out the middle before using the heat gun? What did you use to smooth it out?
I cut the pieces big enough to wrap around the back side a little. Start by stretching the vinyl around the outside and trim the edges. Mine wraps slightly around the back side. I did cut a little out of the center to get it to stretch enough. I cut too much on the first piece and scrapped it. Be patient and good luck.
The back of the wrap is designed to prevent air bubbles which is great. I used my fingers to smooth the wrap.
Cool thanks, I watched a few videos on how to do vinyl wrapping, I think I'll attempt this little project this weekend.
Thinking about doing my bowties too now.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
