my 14 high country has the hard downshift syndrome. bad from the 3-2 shift and horrible from 2-1 nearly screeches the tires. Ive taken it to the dealer twice now, torque converter replaced first time. same problem, then valve bodies replaced, same problem.
so many threads about this issue...where is the fix? I've read countless threads and no one could seem to make this issue go away. aftermarket tuning is out of the question for me. not going to void warranty.
Lol. No GM doesn't care that a large portion doesn't like the operation of the tranny
Sent from my SM-G903W using Tapatalk
theres no way this is normal. my truck does it intermittently 75% of the time. the other 25% of the time it drives as it should
http://www.gm-trucks.com/forums/topic/195861-my-8l90e-is-finally-fixed/
Cliffs: Have them lookup TSB# 14-07-30-001G or find the same if you have the the 6-speed. Even after a new transmission was installed for me I had very harsh downshifts.They performed 14-07-30-001F on mine and the problems instantly went away. I have not had a delayed engagement, harsh shift into gear, or harsh downshift since this was done on 12/29/16.
Edited by Dunc
having the same issues but the only tsb's i have found are only mentioning the 8 speed why would GM fix only the 8 speeds when these issues started with the 6 speeds and no fix for us. my dealer could careless and play the its operating as designed card i don't think down shifts should make passengers lunge foreword but that just me and i get a good bang/clunk right around 30mph up or downshift.
Yeah that TSB is only for the 8-speed vehicles. Good luck getting your dealer to apply it to your truck if it's a 6-speed (there is not a similar TSB for the 6-speed).
Edited by sk
If you don't mind possibly voiding your warranty or are out of warranty a performance tune would probably cure the erratic shifts. I'm sure some people with tunes will chime in shortly...
whats the point of a warranty then? I agree with you the aftermarket tune would fix it. now that's $600 out of my own pocket to fix what should have been fixed for free under warranty.
Yeah, it's BS that GM says its operating normally and won't do anything. I guess most people just deal with it, tune it, or get rid of truck.
I thought someone had a dealer do a fast relearn and it helped his shifting issues.
When you say harsh downshifts, can you explain? My truck I notice if I brake hard, downshifts hard. Brake slow and soft, downshifts soft. it is like the programming of the transmission is set to grade brake down even under normal driving conditions.
Also, what RPMS are you seeing down shifts occur? Mine usually are around 800-900rpm then rise to 1000-1200rpm, until down around 800rpm, then repeat for each lower gear except first, where it goes to idle
I think my tranny as it has aged has got more clunky. 70+K and things just are not as smooth
mine does it at about those same rpms and rises to those same rpms, but it will do it no matter how hard I brake. the weirdest part is some days it doesn't do it, other days it does.
my truck has 96,500 on it. dealer just did the torque converter and valve bodies this week. I would think if GM knew a tune would fix it, they would make a tune instead of replacing expensive tranny parts. but hey I don't care what they do to try and fix it since its under warranty
did the torque converter or valve body make it anybetter? or where they smoked already?
These things are tuned for fuel saving which is awesome to some degree. I know plenty of ford, dodge and tundra people out there looking silly with their fuel mileage. However, I feel it is saving fuel although putting extra wear and tear on good trucks
no change at all. matter of fact it did the usual downshift as I pulled out of the service lot each time I picked it up. banged a U-turn and dropped it back off. now they are saying they've tried it all and theres no fix...but they agree somethings wrong. im not sue what to do here and my warranty is almost up.
I get the whole tuned for MPG thing, but the dam truck doesn't even get good mpg lol. my 2004 Silverado I traded in for this 2014 had 212,000 on it and got 19mpg religiously. this shitbox only gets 17-18
I have ~2500 on my truck and just took an extended trip a week ago and noticed the hard downshift for the first time. Until this trip I hadn't done and hard braking, but I did notice it a couple times during the trip.
Edited by rangerhgm
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 3,083 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
