Led toggle switch help
Hello friends I'm using the tap talk app and the search is not working so hot today... Sorry if we have covered this, I'm looking for help and suggestions on where the heck the mount a toggle switch I really don't want to drill into the truck and my light bar is using one the the blue tooth buttons and that never paired to my garage door like it was supposed to... So now I want to try a switch in the truck.. I'm looking to mount 2 small lights to my hitch here's what I was thinking of using. That's the picture of the harness and button I'd ideally like to put in my truck i have a 2015 all terrain double cab. So what's my best options!?! 4cc122a431245717b18ab0f48fdb6755.jpg15747f013e4c7efc9dd77464ca4061d8.jpg497bb14934a18ad07b860aee2f0441ae.jpg
Sent from my SM-G930W8 using Tapatalk
Good thread but unfortunately it's mostly guys talking about how to wire in that massive switch panel I'm just looking for some clean mounting ideas for a simple switch
Thanks everyone I'm going to use the 12v plug spot did a bunch of search and found out what I need to do basically to get the plug out so should have to much of a hard time setting everything up going to order my stuff shortly. Once again thanks guys!
If you want a good, clean look, I'd look into a different switch that isn't the size of Jupiter.
I bought a nicer switch when I ordered my stuff lol
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,020 Guests (See full list)
