2015 sierra crew making grinding/vibration noise when making sharp lef
Own a 2015 gmc sierra crew cab,noticed that when I make a sharp left hand turn when on a incline,I can hear/feel a grinding/vibration noise,simular to a abs motor noise.Had truck to two different dealers and of course could not duplicate noise.I have truck in 2wd mode,don't notice that hill assist is activating,drivin me crazy since it happens everyday pulling out of my driveway.Any help would be appreciated
