Annoying Noise
I live on some country roads that are less than ideal, and while driving over small bumps, my truck's (2014 sierra) front end sounds like a rattle, almost like something is loose. Truck isn't driving any different, and it may just be the compression of the shocks, but it can be pretty annoying. Anyone else notice this? Or am I just anal?
Try taking a video of the noise. Could help diagnose it.
Sent from my SM-G935V using Tapatalk
Don't you mean "audio" of the noise??? Do you watch the radio??
As long as you can hear the noise in the recording, I don't think it really matters.
I,have the same rattle in the rear.
Is it almost like a shutter? Assuming it's normal?
Like something is lose. I think it's my rear shocks. They might be blown or my u bolts aren't tight enough
I had a clunk in the rear, turned out to be my trailer hitch. Had me stumped for months before it dawned on me.
Havent been able to capture the noise, but have been researching the issue. Looks like it has happened to a few people before, with most people replacing the strut and fixing the issue. Going to take it into the dealership since I still have the certified pre owned bumper to bumper coverage
If it rattles, something is loose. If it sounds like a metallic clank you might want to examine to rubber isolators on the shocks/struts/control arms/sway bar.
My 2016 does this. Really pisses me off.
They claim the noise is coming from my running boards. I just don't know how to insulate them to kill the sound.
You ever find me the noise ? I have a noise on my 13 that sounds like metal hitting metal only when I hit bumps a certain way, I'll send up a video to see if it's close to yours. I have taken the door panel apart and shook everything and can't recreate the noise , it's from the left back door area but my running boards aren't loose :(
They claim it's the running boards, I'll be tightening them to see if that fixed it.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
