On 3/5/2024 at 7:08 PM, Anthonyvee90 said:
....continued
Who did the Titan window install  & Camera in the light ?
What’s up man I did
4 hours ago, Anthonyvee90 said:
What’s up man I did
Nice !!!
I noticed you didn't do the Rubber seal around the glass like a lot of other people do .
hows the window fit  , I assume No leaks  ???
5 hours ago, PAPER said:
Nice !!!
Rubber seal is for the older models.
it fits great and no leaks at all
I've seen them put the rubber seal on newer trucks , thats why I asked .
A place here in Cali ( https://www.instagram.com/reyes.specialties/ )
did My Homies 2018 Crew Cab & they put a Rubber seal around the back window .
Reyes told me he wasn’t doing my truck year no more
so I decided on doing it myself
im not sure though most of the 2014+ truck no one puts a rubber seal
ya they put a Rubber seal on his . the Rubber bunches up in the corners of the window
& lays flat on the straight edges . corners look like ******  !!!
I did
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 495 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
