"Piston Slap" lawsuit?
I just found out my 2002 Suburban has the dreaded "piston slap" or "cold start knock" problem. Unfortunately for me, it now happens at any temperature at almost any time (mostly upon accelleration) although it is not a continuous knock. It is extremely annoying and embarrassing and should definitely *not* be happening on a 1 year old $40k vehicle. GM gave me a 100k engine warranty, but that's not enough.
Is there an organized campaign to file a class action lawsuit against GM on this issue? If not, there should be and I will be first in line.
This garbage that the noise is "normal" or "to be expected" is ridiculous and insulting.
I'd like to hear from like-minded individuals interested in pursuing results by any means necessary.
email me at: [email protected]
thanks,
=Eric
Good Luck and keep us posted.
Try a different dealer, i know in the past some people have gotten their engines replaced.
may I ask have you or anyone else experience any problems other than the noise? (decrease in performance or failure)
I know in 37K miles i havent. GM gave me a 5 yr 100K warranty on the engine
That is NOT cold start knock. It is called spark knock. :cheers:
It should be able to be fixed under warranty and is not considered normal. CSk only happens for the first 30 secs or so after you start the truck, any longer and it is no longer "normal".
Could someone record this piston noise? I have never heard it.
Secondly, and I can't qualify this, I'm certain a redesign of the 5.3 motors (and maybe the others???) for the 2003 year was done which removed the noise. I would think any replacement engines would incorporate this design.
I'm speculating about all of this, unfortunately. But, I do know that my 5.3 with over 10k miles is very smooth and quiet.
It is not "spark knock" as someone reffered to.
A friend of mines truck had it only on cold starts at the beginning ,now it is has gotten progressively worse and does it all the time.
The knock is from the new Hi-performance piston design which were used in the newer engines.
All the info on GM piston slap can be found here including sound.
www.pistonslap.com
I've got 12k on my 2003 5.3. I have had the CSK for a while. It is really quick to go away though, so it doesn't bother me. It's not that loud either. I can only hear it when I am outside and my wife starts it. With that though, I would say that it's probably just a rumor that they fixed it.
My LS1's CSK is a lot louder. Both vehicles were purchased with 75k warranties so I have a long time before I have to worry. Still better than driving a ford.
www.pistonslap.com
Actually, this is a pretty good site. The references and quote resources are better than the authors' own comments and the FAQ, but it is a good site.
My '03 Silverado with the 5.3, is smooth, steady, and quiet. Over 10,000 miles. No oil consumption. The only noisy item on it is the fan.
From this site, I learned that one of our very old Grand AMs that has 135,000 miles on it honestly has very loud audible piston slap. It would always clear up as it warmed up, but the motor has always been well-oiled, well maintained, coolant flushed. This is a 3.4 motor and it has never failed. Going by one of the quote sources at that site, I pulled three of the plugs and did the fan rotation test. Yup, the slap is there. This motor has been noisy since about 30,000 miles and I just thought it was the oil pressure building up at cold start. Going by the site, I'm certain it is audible, knocking slap.
Our newer '99 GrandAm with 90,000 miles on it is quiet. Also with a 3.4. This motor has been smooth and quiet since new.
I dunno... this is a tough call. The noise byte at the web site defitely has a sound like a diesel. I don't think I have ever heard a V-8 that sounded that way except for one that lost oil pressure---the sound I heard reminded me of that.
I don't see what good a new engine will do if changes have not been made. It will still do it eventually in the new one.
the 03's have teflon coated pistons....but it's subject to wearing out, breaking off, and other damage.
My 2001 Silverado with the 4.8l does NOT have cold start knock, but it does have piston slap while accelerating, especially if the engine is under any extra load, even running the air conditioner. They gave me the 100k warranty to shut me up. This slap did not start until 16k. It is quiet as a mouse on start up and even if I rev it up in park or neutral. When I was at the dealer last week to get my tranny checked (it is still there, 4 days now "too many trannys, only 1 tranny guy") I was looking at the '03 SS in the lot. The shark comes out and does the usual "that trucks a beauty etc" I ask him if they fixed the piston slap issue and he say's "oh yea! They put in all new pistons and rings and a new connecting rod made outta some special metal, no problems now!" So I said, if they figured out the problem, are they gonna fix all the others out there with the problem? He smiles and says "have a good holiday". I dont believe him, I have read truck magazines and they talk about the teflon coating and that GM says it is not a reliability issue. BTW, the guy who owned that piston slap website barred me after I questioned why he wanted everybodys vin number, yet he was staying totally anonymous, I suggested that he was using the info for his own war with GM to get compensated +++ for his own engine problem. The next day I could not get in, kinda funny.
This is stupid as heck. Sure these motors make noise. Have any of them failed. NO.NO NO They run good and last a long time!! I am so tired of hearing people whine about a noise that is unproven to cause ANY problems. I have seen numerous of the 6.0, 5.3, 8.1 with 200,000+ miles. Yes they make a noise, but they are still running and running great. That is all the world needs is another attorney involved in something that is not needed. Just drive the dang truck or trade it in.
Bowtiepatriot:
I didn't pay $40k for my suburban to have it sound like a $1,500 piece of crap. This is not "normal" and it should not be happening. I also find it hard to believe that such a drastic noise could be occuring without damage being done to the engine.
I respect your opinion, but definitely disagree.
GM is copping out on this one and that's wrong. They continue to sell trucks with engines that they *know* will do this and that's wrong. They will not properly compensate owners with trucks that have this problem and that's wrong. I will not be able to realize the normal value of my truck in resale or trade-in due to this noise at each start-up and that's wrong.
This whole issue would be a non-issue if GM would have 1) fixed the problem in new engines and 2) replaced the problematic engines with new engines like the other manufacturers have done.
-Eric
I am not getting into a pi$$er over this. Facts show these motors last a very long time and run VERY good! I have to stand with Chevy on this issue, it is not anything other than a noise and is NOT hurting a thing!
So here is the situation and choices you have. Drive the truck and be happy. Or complain and worry and get all in an up roar over NOTHING.
I do not see what if any good will come from a lawsuit. My buddy was involved in a muliti million dollar lawsuit, lawyers made millions he got a check for 6.38$. The only thing a lawsuit will do is raise the cost of the trucks and get some slimball attorney some more money in his pocket. Your motor, my motor and any other's is not going to be replaced. If it was a problem doi you really think that Chevy would put failing motors in all their trucks? And if they were so bad you would see them scattered all along the roadways. They are not failing!
You come into a gm site where most guys here have a feeling of love for Chevy or GM. No matter what the GenIIs are great, poven and probably the very best push rod motors built. This subject has been around since 1997 or earlier, if you did not know about the motors than you did not research your purchase. It is very common and it is not a secret.
    250.3k
    chfkief
    chfkief
  • Who's Online   4 Members, 0 Anonymous, 1,470 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
