2001 Silverado fuel pump
I have a 2001 Silverado with the 5.3. It has 147,500 miles and since the fuel gauge only works about 1/3 of the time, I figured I would replace the sending unit and the fuel pump while I was that far. I know to generally choose the AC Delco brand for replacement parts, but is that the case for fuel pumps? I also see Delphi brand pumps, which GM uses a lot. Does anyone have suggestions or part numbers? Thanks in advance!
Save yourself some headaches and go OEM. If you have a buddy handy just slide the bed back.
AC Delco is OEM right?
If your fuel gauge only works 1/3 of the time, I'd look at the instrument cluster and make sure the stepper motors aren't going out. The stepper motors in that series trucks/SUVs are notorious for going out and giving either no readings, false readings, or erratic readings. You can get the whole instrument cluster (all stepper motors and lighting) rebuilt for $125 or less.
I never even thought of that... I even knew the clusters in these trucks were notorious for having issues. Either way I still plan on replacing the fuel pump, as I do drive a 500 mile route on a routine basis.
AC Delco is OEM parts for GM parts now. GM started Delphi back in the early 90s and morphed Delco Electronics into it, but then spun it off before the General went bankrupt.
If you are having fuel gauge problems, run a few bottles of Chevron Techron Fuel System Cleaner [available at WalMart and most parts stores] [same as GM fuel system cleaner] (NOT the fuel injector cleaner, which Chevron also makes) through a couple of tanks of fuel and see if that fixes the problem. It is famous for fixing sticky floats, and a lot cheaper and easier than an in-tank fuel pump replacement.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
