2017 1500 tires hitting bumper 35's on 20's
I have a 2017 Silverado 1500 crew cab. I put a BDS 6" lift with FOX Coilovers. Cognito UCA's. I'm running Rockstar 20x12 -44 offset and Cooper STT pro 35/12.50 20's and I'm hitting the bumper slightly on the corner. I haven't had an alignment yet so I don't know if that would make much of a difference? I'm assuming I will either have to trim the bumper or put a body lift on it? Anyone running similar and can chime in I would greatly appreciate it. I don't have a pic of the extact spot. I can get it tomorrow. (Best shot I had on phone. It's actually the metal part above that circle) AF8A70B6-AF41-46C3-A715-44B0412B05F9_zps
B3144670-BCCB-410B-896F-94C232AE76CB_zps
Ended up cutting part of the bumper. I had to get it resolved. Back hits a tiny bit only at full lock. I can't go to long without my truck and I already been down a week.
458807DB-B9E3-4CA1-B294-349A0BF0B328_zps
looks sweet man
2015 1500 LT Silverado Midnight Edition
Truck looks great, but that 12" wide -44 offset is killing you. If you change to a 10" wide wheel or a lower offset, your problems should go away.
yeah I know that's the issue. But my truck is raked to hell. If I can get the Coilovers to go up some then I think that would help a ton. I have issues with adjusting them. I have had them off in a spring compressor and still could not get the top to move. Here is a pic of how bad the rake is.
D0538212-E1E1-45F9-8611-B9AEB91CD018_zps
