Vent
Jbui1980
After changing the battery on my GMC Yukon XL the ac blows in the lower vents while very weak in the middle vents, any ideas
Try this:
You might try the HVAC recalibration procedure:
Remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Re-install the HVAC/ECAS fuse
Turn key on, but do not start. Make no adjustments to HVAC controls at this time
Wait 40 seconds for the HVAC control module and actuators to re-calibrate.
I've always had the best luck at this point by turning key off. Removing key and closing the door. (Signals the BCM of a completed driving cycle)
Then climb in in, start and drive.
You can also disconnect the battery in place of fuse removal
http://www.gm-trucks.com/forums/topic/150420-air-door-stuck-on-hot/
Sounds like it got a case of logic lock (or more appropriately, ILLOGIC lock ...).
Powering down the module via txab's instructions should do the trick.
