Could find no info on this document. Any link ?
That is the GM# on their documents? I had the clunk when backing or reversing with steering wheel completely turned. It took the knuckleheads a couple complaints to finally fix it.....well it has not done it since but we shall see.
you need to have the front Cross member TIGHTENED.......GM DOCUMENT #4645801
Is there a sheet with instructions for this? I found PIT 5533, is that the same thing? A google search of GM 4645801 brings up nothing but a single link to PIT 5533 which won't allow you to see it unless you are a subscriber.
Did they say what the problem was that they found? I'm taking mine in next week when they have a loaner for me.
Oh, the cross member. Got previous comments mixed up.
Anyone know the torque spec on the cross member. Mine is making the same bump noise when I cross a slow left hand turn over a rise when I leave my neighborhood just about every time.
Mine ended up being a loose body mount
Ok, good to know and glad it got fixed! Body mount huh? Strange........
Yep, so far no noise. They said it probably came from the factory like that. I've only got 3,500 miles on the truck.
Very interesting. This is something I need to check. I am checking everything that is being mentioned. Today I tightened the cross memeber to 80 ft.lbs. No effect on mine. Still have the bump noise in the front end.
Anyone have any idea how much torque is needed on the body mounts?
Check the lower ball joints too, mine was clunking when turning into my driveway and the lowers were loose. Passengers side had a ton of play in it and the drivers while better was shot too. My 14 4WD has 60k on it FWIW.
PIT5533 covers a creak, click pop crack noise from the front suspension or frame area while making turns on any of the 2015 through 2017 K2 trucks or SUVs.
The noise may be caused by the front frame crossmember. Loosen then retorque the four attaching bolts. On the first pass, tighten to 52 lb ft. On the second pass, tighten an additional 110 degrees.
Road test again to determine if the concern has been eliminated.
https://mp134437.cdn.mediaplatform.com/134437/wc/mp/4000/10391/42497/70171/Presentation/e6/_e6ac6c39-fd10-1f26-173d-3a3fbf768536_/10217.01V_January_2017_EI.pdf
I'm not sure why 2015 and up. Mines a 14 but I'm goingto
check it anyway.
  • 6 months later...
Bumping this thread, as mine is doing this as well. A single pop/clunk every time I back out of my driveway. Sounds like drivers side front suspension area.
Edited by yamaha0343
spelling
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 404 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
