Sunroof and back glass problem.
Jaykota
I was cleaning my truck out over the weekend and decided to open all the doors along with the run roof and sliding back glass. While cleaning the truck my dic displayed a message stating t was in battery saver mode. Charged the battery and now my sunroof will not close nor will by sliding back glass. Both are stuck wide open. Any suggestions or help? They arnt stuck it's as if they arnt getting power. Checked all fuses and they are all good and checked switches too. Any ideas on what to do?
With a fully charged battery, I would try disconnecting the battery cables for a few minutes then reconnecting
Did you try closing them after starting your truck?
Bad battery or cables. Change one or possibly both and the problem should disappear.
